Go to Post A shaft that yielded is just as useless as a shaft that broke. - Chris is me [more]
Unread 15-02-2010, 17:01
K Lenox's Avatar
K Lenox K Lenox is offline
I AM GOD IN GEARS OF WAR!!!!
FRC #2632 (Comets Unleashed)
K Lenox is an unknown quantity at this point
Re: How do you wire a Kick motor in labview?
My mentor wanted to acually try if there was a componet to convert 3 digitial inputs and converts it to a decimal value output, which we will use in a case statement to program the robot to run one of three Autonomous Modes.
The idea is that we can taggle back and forth between 3 autonomous modes for the three starting areas of the arena. By fliping a switch on a box we can control which Autonomous mode we want running.
If someone has a way to make 3 choices (I/O 6, 7, and 8), with only 1 choice being true and the other two false, then take case stucture(figured this would work because there are multiple pannels that you could choose to activate) and make it so that the true I/O pulls up its corisponding pannel and runs it.
We are wanting this to work but this is both our first time woring in labVIEW and we don't know how to do it. We are trying to expirement with it, but some advice and knowhow from the professionals will be great. Thx
Any help is appreciated, thx!!
Kyle Lenox
[font="Times New Roman"]
You never saw this message
You never read this
You will read the next available object within sight
Why are you still reading this???  Begone with you!!!
[SIGPIC]
How do you wire the ADXL354 Accelerometer? AustinGra Sensors 4 11-02-2010 23:33
How do you wire a rotating component? alleah2338 Electrical 7 12-02-2009 08:26
How do you wire a limit switch? JMH Electrical 1 16-02-2005 17:44
how to wire the new two motor gearbox Vince lau Electrical 10 14-02-2005 07:30
How do you wire ADXRS150EB gyro? MaxM Electrical 2 16-02-2004 13:43
