Go to Post I can't wait until IFI starts their FRC sized competition and quickly overtakes FRC. - AdamHeard [more]
Unread 15-02-2010, 17:27
K Lenox's Avatar
K Lenox K Lenox is offline
I AM GOD IN GEARS OF WAR!!!!
FRC #2632 (Comets Unleashed)
K Lenox is an unknown quantity at this point
Re: How do you wire a Kick motor in labview?
Ok heres whats happening.
We are using a motor to pullback a bar, using a dogleg, once it clears the gap, it lets go of the tension and kicks back. Kindof like when you use your foot and bend your knee ato kick something.
What I want to do is build a program where a robot moves forward, kicks a ball, moves forward, kicks a ball, moves forward, kicks a ball. I have it set up so it moves forward, but I dont know if I have it set up right to kick it.
Now, the team want me to devise 3 Autonomous modes. 1 code for each starting position. We can determine which one we want to use by flipping one of three switches on a box to on.
The thing is I dont know how to relate that to programing.
I do know that I have to make 1 of the three I/O true, ant the other two False. Then I need to take the one that is true, and make that ones Autonomous ode pop us and run.
But I dont know how to do that.
RIght now I am work on a possible idea of using elcusive or's to detrmine which one is true. But I would like it to work smoothly and my inexperiance isn't going to help with that. so any help from the pro's is nice
Thx, any help is appreciated
[font="Times New Roman"]
You never saw this message
You never read this
You will read the next available object within sight
Why are you still reading this???  Begone with you!!!
[SIGPIC]
How do you wire the ADXL354 Accelerometer? AustinGra Sensors 4 11-02-2010 23:33
How do you wire a rotating component? alleah2338 Electrical 7 12-02-2009 08:26
How do you wire a limit switch? JMH Electrical 1 16-02-2005 17:44
how to wire the new two motor gearbox Vince lau Electrical 10 14-02-2005 07:30
How do you wire ADXRS150EB gyro? MaxM Electrical 2 16-02-2004 13:43
