Go to Post FIRST is kind of like charity work... you are, even if only in some small way, helping our future just a little bit, and you get a great feeling from it. Even if you are just ringing a bell (or clapping MOE sticks together), you're helping. - Amanda Morrison [more]
Unread 14-02-2010, 16:58
djdaugherty djdaugherty is offline
Mrs. D.
FRC #2053 (TigerTronics)
djdaugherty is on a distinguished road
Wind River Debugging - No such sourcefile
The team is using Wind River with C++ for our software. We are able to download the software to cRIO and control some features. When trying to debug we are following the C/C++ Getting Started Guide and have setup the Target Server as required and see the target server entry populated with tasks. When we follow the debugging instructions we get the Debug Perspective and appear to be able to set a breakpoint. When we select "resume" we get the following error:
Error Message = No such source file position in current context...possibly caused by source not part of executable or wrong path mapping setup Back End ID=6.
Also, can someone point us to the referenced Wind River Workbench User's Guide? Thanks!
Unread 14-02-2010, 18:46
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Wind River Debugging - No such sourcefile
I haven't tried the debugger, but the Windriver manual is http://first.wpi.edu/Images/CMS/Firs...sers_Guide.pdf and http://first.wpi.edu/Images/CMS/Firs...artedWithC.pdf
Watchdog.Kill();
Unread 14-02-2010, 18:58
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
This means the source file you were looking at when you set the breakpoint is not the source file from which the running binary code was built.
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 15-02-2010, 11:26
Trump Trump is offline
FRC #2053
Trump is an unknown quantity at this point
We had a feeling that this was what was happening. Does anyone have any ideas on what we are doing wrong, or how to fix this issue?
Thanks.
Unread 15-02-2010, 12:25
byteit101's Avatar
You could try rebuilding. Right click the project>rebuild and then Debug Kernel Task
Watchdog.Kill();
Unread 15-02-2010, 12:37
FRC #2053
Do we have to undeploy the robot code first, should the crio be in a certain mode? We have already cleaned, and built the code several times... Does rebuilding do something other than this?
Unread 15-02-2010, 14:58
FRC #2053
Heres something else I've found. I deleted all the binary files and the build targets. Then i remade them. Now i am able to debug, but only if i use the step over/ step into commands.
If i press the resume button the process terminates and says <terminated, exit value: 0>tFRC_UserProgram_StartupLibraryInit : 0x1e92678
As a note, when i press the step over/into buttons, it shows only the assembly code.
Unread 15-02-2010, 18:48
byteit101's Avatar
no, at least not to my knowledge
did you configure the debug session? Page 12 of http://first.wpi.edu/Images/CMS/Firs...artedWithC.pdf
Watchdog.Kill();
Unread 15-02-2010, 19:57
FRC #2053
Yes, we have set up everything the way tha the manual says to, but we still can't get it to work. We ended just giveing up on the debug, and we are now useing the printf over serial to debug. Not the best of situations, but we'll have to deal.
BTW: I am just now updateing labview and the driversconsole to the version released today (feb 15).
Also, I saw somewher that you need the driverstation connected to debug?? if so, how do you connect the DS and the proggramming computer at the same time?
Thanks
Unread 15-02-2010, 20:42
byteit101's Avatar
Thanks
If you can only connect one at a time, you have a problem somewhere. Why can't you connect both?
Watchdog.Kill();
Unread 16-02-2010, 07:33
FRC #2053
Im so confused right now. Anyways, the reason we can't connect both is basically because I don't know how to go about connecting both. Do i just plug both into the crio with a Cat5 cable?? I think i set everything up according to the manuals, if not could someone point me to the right page? (i've seen all the manuals that people have already linked to, so If im missing something its because i didn't see it in there.)
Thanks Byteit and others that are helping.
Unread 16-02-2010, 09:14
Mike Mahar Mike Mahar is offline
FRC #0138
Mike Mahar will become famous soon enough
You were given a wireless router as part of your kit of parts. To connect the cRio and the developer PC and the Driver station at the same time, plug them all into the router. You can use the wireless gaming adapter for the robot and then you don't have to plug that in. I would plug in the cRio with a cable to the router first, however.
Unread 16-02-2010, 10:16
FRC #2053
Mike,
WOW, i totally forgot about the wireless . up until now, we have been doing everything wired... I'll try that at tonights meeting. I still have one question. When i debug the program, are the steps to click on the debug kernal task, then enable the robot from the DS? I finally feel like we're getting somewhere. We havn't really been able to get the code to work correctly without debug.
Unread 16-02-2010, 15:54
byteit101's Avatar
yes, you have to click enable on the DS just after the debug starts. I would set breakpoints beforehand, so you can skip to your code.
Entry point
start debug
underlying WPLIB code
DS enable
Your code
PS. Debug is not as easy as Visual studio's Debug
Watchdog.Kill();
Unread 16-02-2010, 22:08
FRC #2053
Still not working . When i press debug kernel task, and then press resume it terminates almost instantly. I don't have enough time to go to the DS and press enable code.
However, i can't press enable code on the DS before i press resume, because it says No Code.
I have the entry point set to Frc_User_library_init, Is this correct??
I really don't know what to do now, without debug we really can't get much done. I spent almost 6 hours today trying to find errors in the code with just printf's coming through the null modem cable, but it really isn't that helpful.
If i'm missing something, please tell me, i think i've seen all the manuals related to Debug, but i might be wrong. If anyone can think of anything No matter how obvious it might seem, please bring it to my attention
Thanks
Uninstall Wind River Lord_Jeremy C/C++ 0 15-01-2009 15:56
SVN wind river Mr.Macdonald C/C++ 3 13-01-2009 12:40
build in wind river Pneumaticsman C/C++ 3 12-01-2009 15:54
Wind River Help BenB Programming 3 02-01-2009 21:42
Open Wind River excel2474 Programming 12 31-12-2008 17:36
