Go to Post Celebrate your failures as well as your successes. - Taylor [more]
Unread 15-02-2010, 19:36
helenajoy helenajoy is offline
FRC #2437
helenajoy is an unknown quantity at this point
Smile WPI Robotics Library
Is there any possible way to accidentally mess up one of the VIs included in the WPI Robotics Library? We think our programming team has somehow modified a WPI Robotics Library VI and that it may be messing up our code from working properly but we aren't entirely sure.
If we did modify a WPI Robotics Library VI and that is our problem, how can we restore the VI?
Unread 15-02-2010, 21:02
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Re: WPI Robotics Library
On your developer PC, check around in one of the directories like the example shown below ...
C:\Program Files\National Instruments\LabVIEW 8.6\vi.lib\Robotics Library\WPI\RobotDrive\Open2MotorWithJaguar.vi
All of the VI's in all of those WPI directories have the installation date ... you could search the WPI (and all sub-) directory for files with a date after your installation date ... if you've got a "bad" one, post up and I'll send you a copy of mine.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Unread 15-02-2010, 21:17
FRC #2437
Okay, we've done that and it doesn't seem like we badly modified any of them.
Thank you!
Unread 16-02-2010, 07:33
One of the good things about MSI is the repair feature. If you think you need it, set aside some time and run the reinstall. Make sure to backup your code first.
Greg McKaskle
WPI library jrws C/C++ 2 17-01-2010 23:22
Need the WPI Robotics Library dude__hi NI LabVIEW 0 27-05-2009 14:20
Location of WPI Library cpp files attached to Windriver marccenter C/C++ 5 11-02-2009 12:47
cRIO-FRC Training Video: WPI Library Overview BLAQmx National Instruments LabVIEW and Data Acquisition 5 09-11-2008 19:58
Where is WPI Library Information PDF? koenig3456 Programming 2 15-01-2006 16:19
