Go to Post I find this ironic. In English class our teacher's tell us how there is symbolism and such, and we don't understand it or think its there. Then FIRSTer's get a Game Hit, and we think EVERYTHING is a symbol and has some significance. - akoscielski3 [more]
Unread 15-02-2010, 21:54
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
mounting the classmate
Has anyone mounted the classmate computer to the driver's station control panel? If so, how did you do it? Velcro?
Brian
Brian K
Team 1225 Robotics Mentor
Unread 16-02-2010, 00:13
Re: mounting the classmate
Ours is attached using three smallish z-shaped polycarbonate brackets. One is on each side near the front, and one is at the rear. Two screws through the base of each bracket hold them all to the wooden base of the control panel.
Unread 16-02-2010, 09:04
SuperBK's Avatar
AKA: BrianK
Thanks Alan, thats along the lines of what I was thinking.
Brian
Brian K
Unread 17-02-2010, 11:48
cmh0114 cmh0114 is offline
AKA: Cam H
FRC #0217 (Thunderchickens)
cmh0114 will become famous soon enoughcmh0114 will become famous soon enough
Just wondering: why do you need to mount the Classmate? It seems like it would make it harder to transport and set up, as opposed to just carrying it around like a normal laptop. :-S
What are the advantages of mounting it?
Unread 17-02-2010, 17:51
SuperBK's Avatar
AKA: BrianK
We are used to having it all together from year's past.
Its part of the drivers console then, all wired in and ready to go, It can be carried from the pit to the game field in one piece. Otherwise, everytime they go to play the game they are going to have to plug in the usb cables in addition to the network cable from the field system. We also don't have to stand around and point fingers and ask "Who forgot to bring the classmate?"
Our console has a cover for storage so its protected when not in use.
Brian
Brian K
Is the Classmate necessary to control the robot in competition? greatman05 FRC Control System 4 10-02-2010 18:55
Can we format the Classmate??? cilginbilgin Programming 4 06-02-2010 04:53
How to transfer the Build file to the Classmate MulletFish Programming 3 14-01-2010 14:34
[BB] So, what about the Classmate? EricVanWyk General Forum 30 13-01-2010 20:04
problems mounting the camera to the 'bot with the default servo/mount set up Redneck Programming 0 16-02-2005 20:53
