Go to Post FRC: more like the real world than we could ever want. - efoote868 [more]
Unread 15-02-2010, 20:43
dag0620 dag0620 is offline
Because we're FiNE
AKA: David Givens
FRC #1071 (Team MAX)
dag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond repute
Question Limit Switch Indicator on Dashboard.
So I was working on the Auto. Code for the robot when one of the Mentors told me that he wants me to figure out how to hook up the following scenario. After looking online, looking at the default code, and just playing around with it, I'm stuck!!!! So here’s the scenario....
Basically we have a limit switch that when rigged up to some other mechanics, goes true when the ball is in range to be kicked by our kicker. What I want is that once this limit switch turns true, I want a Boolean LED on the Dashboard to illuminate so that Drivers know a ball is within range of the Kicker. Any Ideas on how to do this?
Thank-you so much in advance!
David Givens
Alumnus Team Max 1071 ('13) | FIRST Volunteer | NE FIRST
Away making magic for a bit...
Unread 15-02-2010, 20:50
mobilegamer999 mobilegamer999 is offline
FRC #3357 (Comets)
mobilegamer999 is a jewel in the roughmobilegamer999 is a jewel in the roughmobilegamer999 is a jewel in the rough
Re: Limit Switch Indicator on Dashboard.
are you using the standard dashboard that came on the netbook?
Because we're FiNE
AKA: David Givens
Yes I am.
David Givens
Unread 15-02-2010, 22:04
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Then the indicator light for your DIO channel will light up when the switch is pressed. If you want to make it easier on them, make it a BIG light. I recommend using some physical LED that is always in their field of vision, its easier on the operator.
Kettering Motorsports
Unread 15-02-2010, 22:33
chris1592's Avatar
chris1592 chris1592 is offline
Chris
chris1592 is a jewel in the roughchris1592 is a jewel in the roughchris1592 is a jewel in the rough
The way we have it set up on our robot is when the switch is pushed down, the light turns off on our dashboard. When the switch is not pushed down, the light is a solid green. This allows our kicker to always be in the coked position.
Unread 15-02-2010, 23:10
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
The specific instructions vary depending on what language you are using, but overall theory is you add another indicator to the dashboard in LabVIEW (use the example dashboard project) and then modify the datatype for the dashboard and write the value to the indicator. In whatever language you use open the example dashboard and make the same change to the datatype. Sorry i can't help out much more.
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 16-02-2010, 09:49
Because we're FiNE
AKA: David Givens
Hey It's No problem. You've told me much more the I knew before.
FYI I am using LabView - I probably should have included that in the first post.
David Givens
limit switch solomason519 Programming 9 09-02-2010 08:50
Limit Switch Code dnrobotics11 C/C++ 2 13-02-2009 16:22
Using a limit switch to limit motion ManicMechanic Programming 16 20-12-2007 00:54
limit switch wedellm Electrical 4 16-02-2007 13:01
