Re: What Pushed You Toward Mecanum Drive This Season?
The drive you're thinking of is Holonomic, which has four omniwheels, one on each corner and each at a 45 degree angle. It was used by Team 417 at the FTC competition this year.
Chris,
While we are not using Mecanums this year, the thought did come up in our brain storming sessions. A Mecanum Drive theoretically should make gathering balls much easier because you don't have to do as much rotating to keep the ball in place relative to your robot. Also, Mecanum Drives give you additional maneuverability to move around defenders while maintaining the same heading. (Easier to aim and keep ball) Why kept us away from Mecanum was CoG issues. Most of the Mecanum Drives here have the majority of their robot's mass elevated over the wheels because suck a large opening is required between the wheels when climbing the bump which causes CoG to be substantially higher than most conventionally built skid steers. (6+ WD) Also, the added expense of Mecanum Wheels and the Additional Transmissions we would've needed were a factor in our decisions... |
| pic: this is what building season can do to you | kortlan | Extra Discussion | 2 | 05-03-2007 15:26 |
| So What Did You Give this Holiday Season? | MattK | Chit-Chat | 20 | 12-01-2007 00:59 |
| How do you feel toward you robot? | Rickertsen2 | General Forum | 48 | 07-03-2006 00:37 |
| What type of drive train did you make this year? | James114 | Technical Discussion | 31 | 12-03-2005 19:11 |
| One thing you learnt this season | Bharat Nain | General Forum | 75 | 22-03-2004 23:17 |
