Go to Post po-nos, cancans, and totes ma goats - dubiousSwain [more]
Unread 16-02-2010, 02:55
Lumit Lumit is offline
FRC #2521
Lumit is an unknown quantity at this point
Re: Debugging the default targeting code
We don't have a lot of room atm to let it spin forever, but I think that's what is going on... It isn't simply on the wrong side of the middle line, it will turn right into a wall (over 90 degrees) and keep going, even after losing the target in the process.
Unread 16-02-2010, 08:10
Note that the code will turn to gyro heading of zero unless it sees a target. Does the dashboard show a green circle around the target? If not, it may be rotating to the zero.
First determine if the vision code is working just by watching the dashboard. You can also reset the gyro to a safer heading. It is reset using two buttons on the back of the joystick -- I don't remember the numbers.
Greg McKaskle
How do I load the default code? HarryScheiner C/C++ 7 11-02-2009 11:52
The Default Code robocata Programming 1 29-01-2006 17:59
Default code and the Compressor Matthew_H Programming 16 07-02-2005 07:19
problem with the default code MarkVH Programming 7 28-01-2005 00:04
Can't Compile the Default Code pressurex1 Programming 4 25-01-2004 20:26
