Go to Post Fans come and go... but if you're a diehard, you stick around during the losing seasons, too. - Amanda Morrison [more]
Unread 16-02-2010, 03:25
nadavsen2 nadavsen2 is offline
FRC #2231
nadavsen2 is an unknown quantity at this point
Solenoid question..
In a solenoid there is 2 sides..one with 1 connection (where the air supply)
and other side with 2 connections (where the air is commng out)
can i reverse it?
i mean i need 2 air supply to 1 output...
Unread 16-02-2010, 04:48
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
Re: Solenoid question..
just curious but what kind of an application is this for?
Unread 16-02-2010, 07:37
In many cases that answer would be no. The solenoid valves generally use the supply air to help them seal. Reversing would work against those seals allowing a lot of leakage or "blow by". You have to specifically look at the manual for each valve to be sure of your intended application.
Unread 16-02-2010, 07:38
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
You know I have never tried that.
Think of a solenoid as a switch. If you would like to switch between two different pressures then it might work. Using it to combine pressures wouldn't.
The only problem would be that these are pilot operated so there would have sufficient pressure maintained on the output side for the solenoid to work. Also if the difference in pressure is to high it might not work either.
Give it a shot and see but I have my doubts it will work. It may be easier to use two different solenoids to switch from one pressure to another.
Unread 16-02-2010, 09:45
FRC #2231
how can i connect 2 defferent pressure to 1 piston?
i mean, how the solenoids will be?
and im using it for a kick, we want to defferent types of kick..
Unread 16-02-2010, 10:24
You can use yet another regulator to step down the pressure to say 30psi.
Then have a solenoid at the 60 psi level and another at the 30psi level.
Join one outlet from each solenoid in a T-fitting with the third tube going to the cylinder.
You'd only want one of the solenoids 2nd output port tubed to the retraction side, and the other solenoid's 2nd port blocked.
There are other methods as well, this is only one way.
Unread 16-02-2010, 11:25
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
can i reverse it?
If I can guess why you would want to do this, do I get a prize??
OK, in this thread, I asked the exact same question. I also posted a drawing of this application. We tested and this scheme does work as long as you provide pressure above the minimum pilot pressure.
Solenoid Control Valve Question ttldomination Pneumatics 14 24-02-2010 19:08
Solenoid Question RookieWookiez Pneumatics 2 18-01-2010 18:35
Solenoid question from Israel Shomron1690 Rules/Strategy 2 21-01-2007 09:29
Question about Solenoid and default code waialua359 Control System 4 21-01-2006 18:21
Spike/Solenoid Question Dinush Electrical 4 14-02-2004 18:11
