Go to Post My Worst Decision of the Week?? Reading this thread!! :) :) :cool: :cool: - BobC [more]
Unread 15-02-2010, 19:44
Lumit Lumit is offline
FRC #2521
Lumit is an unknown quantity at this point
Debugging the default targeting code
So we're trying to get the default code to rotate towards a target to work. We have a good gyro working (finally), and the camera is detecting our pretend target, but whenever we hit the button, it always rotates to the left.
Any advice on some steps we could do to debug this?
We found that one of the values inside the Rotate Towards Target vi isn't the correct datatype, but that doesn't seem like it'd be enough of an issue?
thanks...
Unread 15-02-2010, 22:34
Re: Debugging the default targeting code
Does it rotate to the left and then stop when it rotates approximately the right amount (just in the wrong direction) or does it continue rotating forever?
Unread 16-02-2010, 02:55
FRC #2521
We don't have a lot of room atm to let it spin forever, but I think that's what is going on... It isn't simply on the wrong side of the middle line, it will turn right into a wall (over 90 degrees) and keep going, even after losing the target in the process.
Unread 16-02-2010, 08:10
Note that the code will turn to gyro heading of zero unless it sees a target. Does the dashboard show a green circle around the target? If not, it may be rotating to the zero.
First determine if the vision code is working just by watching the dashboard. You can also reset the gyro to a safer heading. It is reset using two buttons on the back of the joystick -- I don't remember the numbers.
Greg McKaskle
Unread 16-02-2010, 17:35
seventhapollo seventhapollo is offline
FRC #1477
seventhapollo is an unknown quantity at this point
Our robot also does this. In addition, I noticed that the motor-controller input does *not* vary (to my understanding, it *should*) with the target's distance from the center of the camera view.
Our camera/dashboard *does* see the target - the green circle *is* present. However, the robot simply does not turn properly.
Unread 16-02-2010, 23:08
Originally Posted by seventhapollo View Post
...the robot simply does not turn properly.
The defaults for the PID control parameters might not be appropriate for your robot. To make it turn properly you will have to tune them.
Unread 17-02-2010, 02:26
FRC #2521
thank you Greg,
There is a green circle, it is detecting the target.
We just got done updating to LV2.1 and Dashboard1.1, I'll try to see if it works now, if not then I'll see if I can get more information about where it is trying to turn to.
How might we go about doing that? The PID vi looks way above and beyond my level of comprehension...
Unread 17-02-2010, 06:32
There is a white paper on the NI site specifically for tuning this usage. Give that a try. There are many good tutorials out there for more general usage.
Greg McKaskle
Unread 19-02-2010, 00:07
FRC #2521
The updates somehow fixed it!
How do I load the default code? HarryScheiner C/C++ 7 11-02-2009 11:52
The Default Code robocata Programming 1 29-01-2006 17:59
Default code and the Compressor Matthew_H Programming 16 07-02-2005 07:19
problem with the default code MarkVH Programming 7 28-01-2005 00:04
Can't Compile the Default Code pressurex1 Programming 4 25-01-2004 20:26
