Go to Post We need to find the female engineering mentors in FIRST and start having them present/co-present technical conferences at the championships. We need to start showing the girls on the teams that there are female engineering "rock stars" to look up to. - Kims Robot [more]
Unread 15-02-2010, 15:18
fishLlama fishLlama is offline
Caffeine Addict
FRC #3018 (Team Rocket)
fishLlama is an unknown quantity at this point
Question Tank Drive 'sensitivity'
WPI Robotics Library > RobotDrive > TankDrive.vi
On the built in subVI 'Tank Drive' on the front panel, what does the 'sensitivity' control do?
Our team is looking to find a way to make our drive more smooth, and that may be what we're looking for.
Unread 15-02-2010, 16:51
Omar's Avatar
Omar Omar is offline
Omar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of light
Re: Tank Drive 'sensitivity'
I have looked into that and I could not find where that value is used.
The default setting for squaring speed inputs is true, which will give you a little better control at low speed.
But you could still adjust the sensitivity yourself before passing the values to the motor control VI.
If you square them before passing them I you will get in effect x to the 4th.
Omar
Unread 16-02-2010, 08:58
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
My team uses the joystick throttle as a scale-factor (multiplier) to the standard X and Y joystick values. When the throttle is full on (100%), the full-scale X and Y values are used, but if the throttle is halfway (50%), the X and Y get scaled by 50%. If the throttle is at 0, then X and Y are multiplied by 0 and you get no motion at all.
For this to work, you'll first need to tweak the standard throttle values from -1 to 1 into something that sends values from 0 to 1. To do this, we first add one to it, then divide by 2. Then, if you don't like the throttle orientation, you can flip it by taking the value above, and subtracting it from 1.
Take your "raw" joystick values, multiply this "new" throttle value to them, then wire that into your tankdrive.vi.
We don't use tankdrive, so I'm not exactly sure what sorts of pitfalls that come along with this ... but it's an idea ...
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Unread 16-02-2010, 09:19
the sensitivity is only used in the ratio curve version of arcade.
Unread 19-02-2010, 19:22
JP Carlin's Avatar
JP Carlin JP Carlin is offline
FRC #2487 (Mechanical Animals)
JP Carlin is on a distinguished road
i dont know if this will help you at all but to make the joystick less sensitive i would just divide the values put into the joystick by a constant of 2 or 4 before they go into the ports in tank drive.
Unread 19-02-2010, 21:44
variable joystick sensitivity, see this post:
http://www.chiefdelphi.com/forums/sh...d.php?p=921992
Incorporating Tank Drive Sauce Programming 3 25-01-2010 20:11
Tank Drive vs. Omni Directional Drive jamie_1930 General Forum 9 24-01-2010 22:50
Tank Drive Sauce Programming 1 05-01-2009 18:50
Tank Drive Idaman323 Programming 14 15-02-2005 09:01
tank drive Stormhammer Programming 11 29-01-2004 23:08
