Go to Post Welcome to CD! (just be careful..........it's addictive! :D ) - Jay H 237 [more]
Unread 15-02-2010, 13:37
taysonholzer taysonholzer is offline
FRC #2484
taysonholzer is an unknown quantity at this point
Camera Image Delay
We're experiencing a four second delay from our Axis camera to the Classmate PC. Is this a programming problem or is this just inherent to the operation of the camera? If it is a programming problem, how do we fix it in Windriver?
Unread 16-02-2010, 00:28
buddyb's Avatar
buddyb buddyb is offline
FRC #1885 (ILITE)
buddyb has a spectacular aura aboutbuddyb has a spectacular aura aboutbuddyb has a spectacular aura about
Re: Camera Image Delay
Four seconds? That's *really* significant.
In your teleoperated loop, try placing a "Wait(0.05); //(50 ms)". It has an unnoticeable effect on the teleoperated mode, but allows other tasks to run EXTREMELY smoothly, which may greatly help image transfer. It can also make your program far more responsive.
FRC - Team 1885 - Programmer.
Unread 16-02-2010, 09:29
Mike Mahar Mike Mahar is offline
FRC #0138
Mike Mahar will become famous soon enough
If you install the new Mandatory DriverStation update, this should improve to about a 1/2 second delay. There was a modified Dashboard that was posted last week that removes several CPU hog functions from the Dashboard. We are using that Dashboard and there is almost no noticeable delay in the camera. You have to use the latest DriverStation but you can use any Dashboard.
Unread 17-02-2010, 06:49
From my investigations, the large four or five second lag was typically caused by the laptop not keeping up with the cRIO pushing out images. Some of this overhead was due to some UI stuff in the DS itself related to the cypress I/O. The latest update cuts down the CPU resources needed by the DS, so the issue will likely go away. If it doesn't, run in Developer and look at the task manager to determine if there are other tasks which are contributing. As for comparing different dashboards, I haven't directly compared different ones for performance. If anyone has quantitative comparison, I'm all ears.
Greg McKaskle
Unread 17-02-2010, 08:54
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
If you just want video and don't care about the rest of the dashboard for now, TheDominis has made a lightweight video dashboard. Read about it here:
http://www.chiefdelphi.com/forums/sh...ad.php?t=82422
I'm also making custom dashboard software that will support video in C++ with hardware rendering for maximum speed, but it's not out yet. You can read about it here:
http://www.chiefdelphi.com/forums/sh...ad.php?t=80561
Another thing you can do is get a USB to Ethernet connector and run the dashboard on a faster laptop.
Unread 18-02-2010, 07:27
I certainly don't want to discourage anyone from making a dashboard framework. As long as your are learning and enjoying yourself ...
But until you've measured the speed of the IMAQ display, perhaps throwing around terms like HW accelerated or super-fast is a bit premature. The IMAQ stuff is used in industry and is quite optimized. There are always new and better ways to skin a cat, but that is also why NI pays people to take advantage of such things.
If you have some comparisons worth sharing, I'm always game. I know just who to show it to in order to get IMAQ improved.
Greg McKaskle
Unread 18-02-2010, 10:59
slavik262's Avatar
AKA: Matt Kline
By all means, I'm not discouraging anyone from making their own system. It's a great way to challenge yourself and get something that custom-fits what you need. If anybody wants to pursue their own dashboard system, feel free to contact me if you want any help. That's what the Chief Delphi community is for.
I'm also not saying that the system I'm developing is faster than IMAQ, just that it is fast. I use the term hardware-accelerated because my dashboard can use DirectX or OpenGL as a renderer. When I do benchmarks (eventually), I'll be sure to share them.
Matt Kline
2010 FRC camera vision tracking delay, image processing lag pspeer C/C++ 18 18-02-2010 07:24
camera delay alex42 Sensors 1 15-01-2010 21:23
Camera image? P.Svilans Programming 1 09-03-2009 17:20
Invert camera image? mcb NI LabVIEW 2 21-02-2009 13:23
