Go to Post "You know, a robotics regional is the only place where you can walk in and see two people in chicken suits and not be confused." - Herodotus [more]
Unread 15-02-2010, 20:14
WPfeif WPfeif is offline
FRC #2240
WPfeif is an unknown quantity at this point
Electronics Board and Physics
Not sure if this has been put out yet, but our team has found that by going over the bump, there is a large amount of force on the robot, and by relation, the electronics board. Any ideas for shock absorbers or the like?
Unread 15-02-2010, 20:24
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Electronics Board and Physics
see this thread
http://www.chiefdelphi.com/forums/sh...ad.php?t=81687
Unread 16-02-2010, 10:48
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
These are a good option: http://www.mcmaster.com/#9378k25/=5udjha
Keep in mind, however, that they are designed fairly stiffly - it's actually the mass of the object mounted to them that helps them do their job. Using one to support only a Jaguar, for example, would not help very much. But if everything was mounted on a single board weighing 20 lbs, they could certainly help.
Unread 16-02-2010, 11:57
I like these: http://www.mcmaster.com/#shock-absorbers/=5ueglp
Unread 16-02-2010, 20:37
Liu_yiang Liu_yiang is offline
AKA: Ian Pai
FRC #1245 (Shazbots)
Team Role: Electrical
Liu_yiang is an unknown quantity at this point
We're using an equivalent to these (ours came from home depot/Lowes): http://www.mcmaster.com/#washers/=5ul4g2
Stack up a bunch of hard rubber washers, it's pretty cheap. We had 6 stacked up for the main board (CRIO, Sidecar, distribution board, 2 spikes, circuit breaker, and game controller).
Unread 16-02-2010, 23:37
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Our solution to this: Dont go over the bump. Due to the amount of stress on our robot in our bump testing today, we are opting out of bump support, and are going to lower the top of the robot to tunnelize it.
Unread 17-02-2010, 00:11
sbrumund sbrumund is offline
FRC #2115 (M cubed)
sbrumund is an unknown quantity at this point
We were able to purchase isolation mounts for the main circuit board from McMaster Carr. Note the CRIO is rated for 100g's. We were more concerned with wires coming loose than damage to the electronic equipmdent.
We made isolation mounts for our jaguires using 2 pieces of 1/8" plywood with egg crate foam between the plywood which works better than the comercial mounts.
In addition we are using pneumatic wheels the reduce the impact forces when going over the bumps.
Our suspension keeps all four wheel on the gorund as we go over the bumps to reduce the hammering the robot takes as it comes down the back side of the bumps.
Without the above modifications we managed to break one of the kit wheels
pic: Electronics Board Team2339 Extra Discussion 1 15-01-2009 19:31
ABS Electronics Board Ian Curtis Electrical 3 07-01-2008 23:25
pic: Electronics Board and Drive Cassis Chris Fultz Extra Discussion 6 01-03-2007 16:40
pic: Side of electronics board keenanmolner Extra Discussion 1 18-02-2007 20:15
pic: 701 Electronics Board Doug G Robot Showcase 19 13-02-2006 19:40
