Re: Overweight!?
http://frcdirector.blogspot.com/2010...-year-and.html
Re: Overweight!?
I can well remember seeking out free machine shop services to put steel chain sprockets on a diet. Or a couple hours with an angle grinder and a cutoff wheel to spider-web a pair of 60 tooth #35 steel sprockets. Eventually, you try to get in the habit of weighing and estimating as you go.
Re: Overweight!?
Re: Overweight!?
But then you can at least estimate the size of the drills you need to hog out holes.
Re: Overweight!?
91 lbs with battery...when we weighed the battery it listed at 14 lbs so we figure we're at 76 - 77 lbs...first time we've EVER been this far under
Kind of scary though when you think about possible shoving matches! |
Re: Overweight!?
We weighed ourselves tonight - 82.5 lbs. We still need to add:
- cRio - kicker assembly - hood/roll bar We figure with all that, we're still going to be 10-20 lbs light. Which just means we get to use some steel plates again to help position our center of gravity (when the battery is included, we suspect it will be slightly to the back as it is now). |
#7
Re: Overweight!?
Weirdly we are at about 65pounds, we were so shocked when we read it. Looks like someone's robot is getting a nice shiny steel exoskeleton lol
#8
Re: Overweight!?
haha we weighed in around 118lbs
#9
Re: Overweight!?
67 lbs sans kicker at last weigh in... we're definitly going to be adding weight low down i think...
| Are You EPICALLY overweight? | ZakuAce | General Forum | 89 | 17-02-2009 09:34 |
| About being overweight and exceeding your size requirements – the need for reinspecti | Godzilla! | General Forum | 48 | 28-03-2006 11:11 |
| pic: 7 lbs overweight | CD47-Bot | Robot Showcase | 9 | 23-04-2004 02:27 |
| OVERWEIGHT | COOKIE | General Forum | 18 | 14-02-2002 07:53 |
