#9
Re: Continued problems with Cypress I/O Board
And the Red Power boost USB cable doesn't help?
What kind of switches are connected to the I/O board? What else is on the hub? Can you just connect both the I/O board and the hub directly to the two available Classmate USB ports? And everything else into the hub? |
| FRC Q&A Clarifies use of "Carrier' boards with Cypress FirstTouch Board | eStop Robotics | General Forum | 3 | 10-12-2010 15:38 |
| Sensitivity of Cypress board | SteveD | Control System | 1 | 21-01-2010 11:22 |
| Cypress board | bls0620 | Electrical | 4 | 17-01-2010 23:22 |
| Problems with IR Board | Mark McLeod | Sensors | 79 | 16-02-2008 20:57 |
