Go to Post I'm so conflicted right now. On one hand, you made the same page as a celebrity. On the other hand.... Justin Bieber. - Akash Rastogi [more]
Unread 16-02-2010, 16:10
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Circle Tracker Demo
Originally Posted by nomad725 View Post
I am trying to port the demo code into our code when I found out the Tracker demo uses the robot drive class. Anyone have/know how to change this into two independent Jaguar motors?
The RobotDrive class will work with either 2 or 4 Jaguar controlled motors. You just need to call the constructor with the port numbers that each of the Jaguars is connected to. You can find the call to the constructor in the 4th line in the CircleTrackerDemo class definition:
RobotDrive drive = new RobotDrive(1, 2);
You can also replace the 1, 2 with two Jaguar objects if that is what you're asking:
Jaguar jag1 = new Jaguar(1);
Jaguar jag2 = new Jaguar(2);
new RobotDrive(jag1, jag2);
Brad Miller
Robotics Resource Center
Line Tracker Mounting Bracket Zuelu562 VEX 0 01-02-2010 08:59
Tracker Code Yellow Eyes Programming 3 21-02-2004 11:14
Infrared tracker Nick R. Electrical 1 14-02-2004 17:24
IR Sensor-tracker.zip alexrobotics Technical Discussion 7 06-02-2004 09:09
score tracker VanWEric Programming 21 06-01-2003 16:58
