Go to Post It is hard to write code that conforms to a standard that isn't published... - AustinSchuh [more]
Unread 15-02-2010, 11:26
Elean Atencio's Avatar
Elean Atencio Elean Atencio is offline
Software Mentor
AKA: Elean-1065
FRC #1065 (The Moose)
Elean Atencio is an unknown quantity at this point
LEDs on driver station
How can i get the LEDs in the drivers station to work when a Digital input is true/false or a solenoid is on/off?
Unread 16-02-2010, 16:13
AKA: Brad
#0190 ( Gompei and the Herd)
Re: LEDs on driver station
There is a setLED() method on the DriverStationEnhancedIO class. You can use it by supplying a channel number (1-8) and a boolean value (true, false) that will operate the LED. The DriverStation must be set to use the Cypress enhanced I/O board in order for this to work.
Brad Miller
Robotics Resource Center
Driver Station? qpang FRC Control System 2 27-01-2010 16:59
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 10-01-2010 15:04
Driver station... the man Control System 16 06-01-2010 21:06
Driver Station S.O.S. M. Gildner Electrical 15 28-11-2009 19:35
driver station corps FRC Control System 5 06-08-2009 20:44
