Go to Post We were all rookies once, and we really have two ways to go about things: either take a page from the powerhouses and emulate their style, or complain about not having anything and risk falling into oblivion. - George A. [more]
Unread 28-01-2010, 17:30
Abole Abole is offline
FRC #3284
Abole is an unknown quantity at this point
Where is the design tab located?
I'm trying to find the design tab to help me build a chain for 2 sprockets. I'm following a tutorial to build one and it tells me to click on the desgin tab in the ribbon. Thanks
Unread 28-01-2010, 18:16
Bob Steele's Avatar
AKA: Bob Steele
Re: Where is the design tab located?
It might help if you told us what program you were using....
Unread 29-01-2010, 11:49
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
that function is useles for FRC, i've tried it
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 29-01-2010, 12:07
Allison Allison is offline
AKA: Allison Phelps
FRC #1024 (Kil-A-Bytes)
Allison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant future
Assuming you are using Inventor:
1. Make an assembly file
2. In your assembly file across the top there will be tabs (assemble, design, etc)
3. Under power transmission click the drop down next to v-belts and select roller chains.
I hope this helps
Allison
Unread 29-01-2010, 12:23
joek's Avatar
i tried it, and it didn't work, it wouldn't go from the output sprocket to the sprocket on the mechanum
Unread 03-02-2010, 01:41
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
All,
Difficult to tell the exact problem, but I suspect that you need to change the options under Sprocket Geometry Option.
1. In the Roller Chains Generator dialog box, click the down-arrow beside Sprocket. There are 3 options, Component, Existing, Vitrual.
2. If the sprockets already exist (and it sounds like they do) select Existing.
3. Keep in mind that it generates a solid representation of the chain or a sketch. We do not need to see actual chain links in a design, the chain data is more important.
Phil
Unread 03-02-2010, 16:29
FRC #3284
Sorry, took so long to reply, i found the design tab, just forgot about the assembly part of it from an ipt... thanks though, and it was for making the chains
Unread 03-02-2010, 19:00
joek's Avatar
ok, i used the roller chain generator, and it said this:
"chain drive trajectory is corrupted or data are inconsistent with build in rules. calculation cannot continue"
and
"no sliding sprocket within the chain drive. please set one sprocket as sliding."
Unread 16-02-2010, 17:13
FRC #3284
You might need to put a sprocket, so there is a place that the chain can start from. Thats one thing i noticed but it was easier just putting them straight in on the assembly of the whole robot.
Unread 17-02-2010, 13:44
joek's Avatar
i started a thread about this after my post.
[Official 2008 Game Design] OK, so YOU design the 2009 game... dlavery FRC Game Design 69 23-08-2009 19:54
[Official 2007 Game Design] OK, so YOU design the 2007 game... dlavery FRC Game Design 44 17-12-2006 17:05
So wats ur teams name and were are you located C-MAN Chit-Chat 27 18-10-2004 17:54
TAB command in Pbasic virusmirusne Programming 11 25-01-2003 02:51
