Go to Post I mean, there is a 40 second period where your alliance has to play defense, so you might as well play it well. - Jeff Rodriguez [more]
Unread 13-02-2010, 07:16
gabi0407 gabi0407 is offline
FRC #2669
gabi0407 has a spectacular aura aboutgabi0407 has a spectacular aura aboutgabi0407 has a spectacular aura about
mecanum wheels.
we bulid our mecanum wheels but we don't know how to put the Wheel bearings.
what can we put there that the Wheel bearings will not slip into ther wheel?
Unread 13-02-2010, 08:26
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Re: mecanum wheels.
You'd need flange bearings.
But, I have to ask...Are you direct driving the wheels? Or chain Driving? Mecanums are usually set up direct drive off of the gearbox, and thus you don't need breaings only a hub with a keyway. Thats the way we're doing it.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 13-02-2010, 08:42
FRC #2669
Re: mecanum wheels.
thanks.
when you meen direct driving you meen that the wheel is dicetly on the shaft of the of toughbox?
and if it is like that isn't this dangerous for the toughbox?
Unread 13-02-2010, 09:17
AKA: Scott
Re: mecanum wheels.
Correct. Direct drive would be directly connected to the output shaft of your transmission. And no, this won't hurt the transmission, this is what its designed to do.
Oh, and if you are chain driving, your going to need a pretty big sprocket spacer in order to clear the wheels.
Unread 13-02-2010, 09:31
FRC #2669
Re: mecanum wheels.
thank you very much.
yes i know i need some big spacer and it is not a problem to get but i steel prefer direct driving.
can i use the regular toughbox from the kit of parts
is this bearing will be fine http://andymark.biz/am-0077.html
and scott thanks you help me a lot
Unread 13-02-2010, 10:02
AKA: Scott
Re: mecanum wheels.
No problem, thats what we're here for
And yes thats the correct hub for the Kit of Parts Toughbox. I don't know if it makes a difference or not, but my team is using the 8" mecanum wheels this year, and we choose to use 2 hubs per wheel (on on each side) for added strength to the side walls of the wheels.
If you have any other questions feel free to message me on here.
Unread 13-02-2010, 10:20
FRC #2669
Re: mecanum wheels.
thanks.
for now i have no more questions.
Unread 16-02-2010, 13:54
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Re: mecanum wheels.
no, they're usually chain drive, no one uses directdrive on their wheels that i know of
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 16-02-2010, 14:01
Re: mecanum wheels.
Direct drive does NOT mean directly from the motor. It means it is directly driven off of the gearbox output shaft. Many teams do this, even with mechanum wheels.
Unread 16-02-2010, 14:50
BEEKMAN BEEKMAN is offline
AKA: Brendan McLeod
FRC #0190 (Gompei and the Herd)
BEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to behold
Re: mecanum wheels.
Yeah, the only time we've done a chain was last year. Chains are more common on non-mechanum types, because you likely need to control two wheels with one motor
Unread 16-02-2010, 15:51
AKA: Scott
Re: mecanum wheels.
Agreed. I even specifically said transmission numerous times. Oh well...
Unread 16-02-2010, 17:18
FRC #2669
Re: mecanum wheels.
i did this like scott say and it is works perfectly.
Unread 16-02-2010, 19:28
AKA: Scott
Re: mecanum wheels.
Awesome, glad to hear everything worked out for you guys!
Mecanum Wheels CollmandosGrl CAD 2 17-01-2008 10:23
Mecanum Wheels Calvin_1631 Motors 7 09-02-2007 13:29
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Mecanum Wheels chaolin2007 Control System 1 25-02-2006 19:16
Mecanum Wheels TheFerret Technical Discussion 8 16-01-2006 09:23
