So here is the run down. We have been able to deploy our code before and the robot would run and we were able to move it and everything. However recently we were transfering some equipment and it has stopped working. On the driver/developer end using a labview template provided, as before, the robot was communicating and the code was found. So everything seemed to be working on the laptop's end, but when trying to use the joysticks nothing responds. I've checked the error log and nothing but a vision error due to a lack of camera as before. The wiring on the robot has been double checked and the battery is not the issue because we replaced it with a fully charged one yet still no response. Please help if you think you have a solution....
Re: HELP/SOS: Everything seems to be working but.....
Have you tried doing a full restart of both drivers station, and robot? Normally whenever we have problems, doing this fixes everything.
We've tried rebooting the cRIO, and the Allen Bradley signal light is not lighting up what so ever. However it is deploying the code and the code is being accepted, any other ideas?
Thanks guys but we got it now junked around with some cables and now it works YAY!!!
Did we learn anything from this?
| Camera tracking code not working in our own program, but works in CircleTrackerDemo | TPNigl | Programming | 3 | 31-01-2010 19:40 |
| Code downloaded but not working... :( | pudgeball | C/C++ | 4 | 28-01-2010 11:04 |
| [TBA]: MP4 vs. WMV, MP4 seems to be working well | Greg Marra | The Blue Alliance | 8 | 24-03-2008 23:56 |
| SOS!!! Need some help!!! | SL8 | Regional Competitions | 3 | 19-02-2008 01:18 |
| frc_camera not working but labview does | Issues | Programming | 7 | 18-01-2006 19:23 |
