Go to Post The world isn't changed by people playing it safe. - Andrew Y. [more]
Unread 11-02-2010, 18:33
Cjdowney's Avatar
Cjdowney Cjdowney is offline
AKA: Cody Downey
FRC #3176 (Purple Precision)
Cjdowney is an unknown quantity at this point
Code Deploying Problems[Java]
We are able to deploy the code onto one of our robots, but our other one drops the code while deploying.
We are using Java on a v19 cRIO and we have tried re-imaging the cRIO more than once. We tried resetting the robot and the router and we also tried copying it onto a new project.
Does anyone know why or have a theory on why this is happening?
Unread 14-02-2010, 14:07
KevinJ KevinJ is offline
Bit Wiggler
AKA: Kevin Janesch
FRC #1533 (Triple Strange)
KevinJ is an unknown quantity at this point
Re: Code Deploying Problems[Java]
Have you confirmed the configuration of the radio on the robot in question and/or tried connecting the cRIO straight to the computer to load code?
Also, what messages does Netbeans spit back when it fails to deploy the code?
Unread 16-02-2010, 18:06
Cjdowney's Avatar
AKA: Cody Downey
Sorry for not doing so before now, but the edit button wouldn't show on my topic post and didn't want to double post. We've already solved the problem, but thanks for your attempt.
Need Help With Deploying Code Darth Pbal National Instruments LabVIEW and Data Acquisition 2 02-02-2010 19:20
Need Help With Deploying Code Darth Pbal National Instruments LabVIEW and Data Acquisition 0 02-02-2010 13:19
Net Beans Deploying the Java Code UverSekai Java 2 20-01-2010 17:15
Issue deploying Code rudun Java 5 18-01-2010 21:24
Problem deploying/running default code blaxbb FRC Control System 0 10-01-2009 11:59
