Go to Post CD threads are supposed to be about something? - Tim Baird [more]
Unread 15-02-2010, 17:47
Twisted eric's Avatar
Twisted eric Twisted eric is offline
FRC #0581
Twisted eric is an unknown quantity at this point
Question Programming the teleop
My programming team are stuck
like the title says I'm tying to program I don't know what I'm missing
code
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Watchdog;
public class Demonized extends SimpleRobot {
RobotDrive drive = new RobotDrive(1, 2);
Joystick leftStick = new Joystick(1);
Joystick rightStick = new Joystick(2);
Watchdog Fenrir = Watchdog.getInstance();
public void autonomous() {
while(true && isAutonomous() && isEnabled())
for (int i = 0; i < 4; i++) {
Fenrir.feed();
drive.drive(0.5, 0.0); // drive 50% fwd 0% turn
Fenrir.feed();
drive.drive(0.0, 0.5);
drive.drive(0.0, 0.0); // drive 0% fwd, 0% turn
public void operatorControl() {
while (true && isOperatorControl() && isEnabled()) // loop until change
drive.tankDrive(leftStick, rightStick);
Timer.delay(0.005);
Fenrir.feed();
help will be much appreciated
team 581
Unread 16-02-2010, 16:04
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Programming the teleop
You need to "feed" the watchdog timer in the operatorControl() method. I'm not sure if that's what you're seeing, but I would expect that you are getting a "Watchdog not fed" message on the driver station.
Insert a Fenrir.feed() in the loop with the drive.tankDrive() call.
Brad Miller
Robotics Resource Center
Unread 16-02-2010, 17:26
FRC #0581
Thank you that was what i was missing any help with the pneumatic compressor.
Unread 16-02-2010, 18:18
FRC #0581
code
import edu.wpi.first.wpilibj.Compressor;
Compressor Siberian = new Compressor(1,1);
Fenrir.feed();
Fenrir.feed();
Timer.delay(0.005);
Fenrir.feed();
new code update
Unread 16-02-2010, 18:36
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
add a Siberian.start() to the outside of your while loop
Unread 16-02-2010, 18:53
FRC #0581
which wiled loop auto or tele op
OH
and can everyone help with sensing pressure and every thing first time using java.
Unread 16-02-2010, 18:57
1 * 4 != 14
Talking Re: Programming the teleop
i reccomend you make a setupRobot method for stuff like that.
insert the following inbetween the autonomous and teleop code
void setUpRobot() {
Siberian.start();
Fernir.feed();
then just add setUpRobot(); to your teleop and autonomous code.
That should fix it
Unread 16-02-2010, 19:10
FRC #0581
void setUpRobot() {
Siberian.start();
Fernir.feed();
That should fix it
Thanks
do you know how to sense pressure value and auto shut off
Thanks in advance and sorry for so-many questions.
Unread 16-02-2010, 20:11
1 * 4 != 14
Dude, its ok, i had the same questions.
it will automatically shut off as long as the wiring is correct (check the diagrams), so programming can now rest easy.
Unread 16-02-2010, 20:48
FRC #0581
in the pneumatics manual here (http://www.usfirst.org/uploadedFiles...%20Rev%20-.pdf)
says that there is no default program in the cRIO to control
the compressor power.
Unread 16-02-2010, 21:48
1 * 4 != 14
its always worked for us
Enable Teleop in Robot Main ThisAintJeff NI LabVIEW 4 04-02-2010 14:33
NXT Mindstorm Teleop EXamples johncap100 FIRST Tech Challenge 4 10-10-2009 09:48
problem with passing doubles back into the "TeleOp Execute" loop windell747 NI LabVIEW 1 21-03-2009 00:50
Teleop Lag Xavier Brandall Programming 14 17-03-2009 18:21
Detecting Start of TeleOp Mode Danny Diaz Programming 4 26-02-2008 01:37
