Go to Post Programmers fuel: pure, unadulterated caffeinated beverages. - Mike [more]
Unread 16-02-2010, 12:32
tweeter tweeter is offline
tweeter is an unknown quantity at this point
Question about compiling
OK, the scenes are rendering individually as MOV files. But I don't know how to piece them together and add the sound files.
Do I need extra software to do this, and if so, is it expensive?
Are there already any instructions about how to do this that I overlooked?
Thanks for any help,
TW
Unread 16-02-2010, 12:44
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Question about compiling
I am not doing anything related to FIRST animation, and have not read the animation stuff, but my previous video knowlege tells me two things:
1. MOV = BAD. Unless the rules or directions specify them I would stay away from them. They are QuickTime files, and until you are done they are hard to work with because most software dosen't like them. They have good compression, so if you want to export to web they will work quite well, but use AVI or if you have to MPEG until you are done. Then, export the final composite in MOV and MPEG.
2. I have previously used Adobe PrPro for editing, it works great but is expensive. Any normal video editing software that accepts MOV's should work for compiling. On Windows WinMovieMaker won't like MOV's, but iMovie will like them very much (and only use them). Depending on your OS there are some free tools that are available, I have use Cinelerra on Ubuntu (note - it will really only run on a few linux distros and requires some work to install), my Windows software is all Adobe and fairly expensive. There may be a tool in the animation software to do it, I would check there first.
Kettering Motorsports
Unread 16-02-2010, 13:23
rastermon rastermon is offline
FRC #0847
rastermon is an unknown quantity at this point
Clearly, you have not.
They specifically request it in 720x480 Quicktime NTSC DV Codec 29.97 fps.
We composed our movie in Autodesk Combustion - which Autodesk provided.. last fall. But when I tried to download it again, it was not among the software available.
Quicktime Pro for about $30 will do it (though I have never used it)
The last time I used iMovie it destroyed the resolution - looked horrible.
Unread 16-02-2010, 15:03
kpp58 kpp58 is offline
AKA: Kevin Perkins
FRC #0058 (RiotCrew)
kpp58 is an unknown quantity at this point
We are in the same boat. We assumed that Toxik was the software to use but can't import video files.
Any answers?
Unread 16-02-2010, 18:24
MadeAtMidnight's Avatar
MadeAtMidnight MadeAtMidnight is offline
AKA: Carrie Asner
FRC #1625 (Winnovation)
MadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud of
I was surprised that Combustion was not available for download, too. But, you can download a free 30 day trial at the Autodesk site.
Carrie
League of Mothers founding member
"There are two ways to spread light; to be the candle, or the mirror that reflects it."
Edith Wharton
Unread 16-02-2010, 18:33
AKA: Kevin Perkins
We're going with imovie to put it all together.
Unread 17-02-2010, 15:25
FRC #0847
Yes, but it renders a red X on every frame - a true trial version....
Question about sponsor May_Walter General Forum 3 16-02-2009 14:20
Question about bumbers and stuff about our chassis Cow Bell Solo Rules/Strategy 10 21-01-2009 16:56
Question about Kickoff. captainking General Forum 2 10-01-2009 13:04
A question about rendering -PauL- 3D Animation and Competition 3 02-07-2004 11:44
Question about scoring.... Katie Reynolds Rules/Strategy 2 06-01-2002 10:37
