Go to Post First'ers aren't 'normal' I guess. Whatever that word means now a days - dancingfool [more]
Unread 15-02-2010, 19:41
xtenext's Avatar
xtenext xtenext is offline
rawr uba scary-man
FRC #2594 (NASKCOrpion)
xtenext will become famous soon enoughxtenext will become famous soon enough
Send a message via MSN to xtenext
Unhappy System Updates
We installed the Feb 15 system update and now we have system conflicts between the dashboard vi. How do we fix that?
Unread 16-02-2010, 10:20
scorpions980 scorpions980 is offline
FRC #3017
scorpions980 is an unknown quantity at this point
Re: System Updates
we also installed that this morning and since then we've been having a problem downloading the code to the cRIO and we have been consistantly getting the no code error. its been working fine up till now. anyone have an idea how to fix this?
Unread 16-02-2010, 11:13
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: System Updates
Make sure you update both Labview and the Driver's station to the latest version. There is an update out for both of them. After you do that make sure to reimage the cRIO with the latest image (v20).
Unread 16-02-2010, 12:41
jingmeiguo jingmeiguo is offline
FRC #1912
jingmeiguo is an unknown quantity at this point
Re: System Updates
After we installed the Feb 15 updates, the PSoC I/O board not working any more. The same I/O board is working on laptop with driver version 3.2.0.4, but not working on the newly updated laptop with diver version 3.4.1.20.
Any suggestions ?
Thanks.
Unread 16-02-2010, 13:27
pilum40 pilum40 is offline
Steve Miller-Coach-Team 3355
AKA: Steve Miller
FRC #3355 (Bigg Redd)
pilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud of
Re: System Updates
Any suggestions ?
Thanks.
What would happen if we don't upgrade since everything works right now?
Dumb question...right?
Unread 16-02-2010, 16:26
FRC #1912
Re: System Updates
We have installed both updates and re-imaged the cRIO (BTW: on one of the laptop we have to re-image a few times till it worked).
I am wondering what caused the PSoC driver version difference between my dell (winxp, with V3.2.0.4 which is the same version as before we loaded the new updates) and hp (vista with v3.4.1.20).
Unread 16-02-2010, 18:40
umangv620 umangv620 is offline
Programming Captain
AKA: Umang
FRC #1403 (Cougar Robotics)
umangv620 will become famous soon enoughumangv620 will become famous soon enough
Re: System Updates
where is the cRIO update? Was it released today also? or has it been out for a while? i dont remember what version our cRIO is at.
Team 1403 Cougar Robotics
2009-2011 Programming Captain
2010
NJ-Regional - Chairmans Award
Unread 16-02-2010, 18:41
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: System Updates
The new cRIO image is installed with the Labview Update. After installing the Labview update, when you run the cRIO imaging tool you should see v20.
Unread 16-02-2010, 19:35
Programming Captain
AKA: Umang
Re: System Updates
alright thanks!
2010
FVC updates royal_robotix General Forum 0 23-10-2006 22:49
Rule updates.. Brandon Martus Announcements 17 11-01-2005 19:26
More Updates.. Brandon Martus Announcements 23 27-09-2004 10:53
Updates? archiver 2001 0 23-06-2002 23:26
Regional Updates????? Chris Hibner Regional Competitions 19 19-03-2002 09:17
