Go to Post FIRST is not about winning awards, it's about learning and advancing the human culture - crispyc [more]
Go Back   Chief Delphi > Technical > CAD
Unread 16-02-2010, 18:53
spacegy4's Avatar
spacegy4 spacegy4 is offline
Is a CAD
AKA: Andrew Sternglass
FRC #0639 (Code Red Robotics)
spacegy4 is a name known to allspacegy4 is a name known to allspacegy4 is a name known to allspacegy4 is a name known to allspacegy4 is a name known to allspacegy4 is a name known to all
Send a message via AIM to spacegy4 Send a message via MSN to spacegy4 Send a message via Yahoo to spacegy4
How many parts are there in your robot assembly?
Team 639's CAD model of our robot (Link to render) consists of 503 parts. (this was determined by the count of total occurrences in the active document: That being the assembly) How many does your team's robot assembly have?
"When you pull the project out of the fire and make the robot dance, thats real education."
Woodie Flowers: 2010 Kickoff
Unread 17-02-2010, 01:16
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
Re: How many parts are there in your robot assembly?
Right now we are at 580 parts for the final robot, not including bolts.
Unread 17-02-2010, 06:45
ravichauhan ravichauhan is offline
FRC #0612 (Chantilly Robotics)
ravichauhan is an unknown quantity at this point
489 without the belts or fasteners
Unread 20-02-2010, 16:43
meganmc's Avatar
meganmc meganmc is offline
MeganM - Team 1296
AKA: Megan McClellan
Team Role: CAD
meganmc is an unknown quantity at this point
Question Re: How many parts are there in your robot assembly?
How is it that you have so many parts? This is my second year being in charge of CAD and I am the only one working on it, causuing me to have numerous issues. Autodesk continues to tell me that I am running out of memory in the assembly. I have started shrinkwrapping individual parts and making a new assembly everytime I add a new part. Do you have any suggestions?
Unread 20-02-2010, 16:46
spacegy4's Avatar
Is a CAD
It would probably be the case that you don't have enough system RAM. What are your system specs?
the only one working on it? That is really too bad man. I feel bad for you. Are you at least getting mentor help?
Unread 20-02-2010, 17:08
meganmc's Avatar
MeganM - Team 1296
Team Role: CAD
The main hard drive on the school computer is only a 75GB one with a 2GB RAM. I am not real sure what mine is on my laptop but I have the same issues on three different computers. I finally gave up and started doing sub-assemblies inside sub-assemblies.
And yes, it is bad. No, I am not really getting much mentor help. We have our main electrical engineer that knows some SolidWorks, so he helps when he can. Our main sponsor helps out a little bit too, but in general, I am the main one working on this. There are a few people that are trying to learn from me before I leave, but mostly, they work on the robot or non-robotic construction(i.e. field, bumbers).
Do you have any reccomendations of what I can do? I am quickly running out of space, and I am worried that this will not be completed.
Unread 20-02-2010, 17:19
spacegy4's Avatar
Is a CAD
Running out of memory in the assembly? Does it mention virtual memory? I would try closing all the other programs that you are not using to free up memory for inventor.
Unread 20-02-2010, 17:27
meganmc's Avatar
MeganM - Team 1296
Team Role: CAD
Yes, the assembly. And now that I am looking, I am seeing that it does mention virtual memory. The exact phrasing of the pop-up that comes up is: "Your Inventor session is using 82% of available virtual memory." Then it follows with ways to reduce the memory usage(like shrinkwrapping).
I will try closing the internet that Mr. President of our team opened on this computer while I was looking at the robot.
You are a lifesaver! Thank you so much!
Unread 20-02-2010, 17:35
spacegy4's Avatar
Is a CAD
If you use firefox that may be contributing to it. It has a memory leak problem that can result in it accumulating memory over time
By using control alt delete to open the task manager you can see how much memory each task is using.
Unread 20-02-2010, 17:37
meganmc's Avatar
MeganM - Team 1296
Team Role: CAD
Ok. Thank you again! I will probably be posting on here again if I need more help.
"I want a group of Supernerds. I want Supernerds everywhere"
Woody Flowers: 2010 Kickoff
Unread 20-02-2010, 17:39
spacegy4's Avatar
Is a CAD
It might make more sense for you to send me a private message or post a new thread. So we don't hijack this thread for any longer.
Unread 22-02-2010, 12:25
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Create a folder and put all your fasteners in a folder. Then suppress the folder when you are working on subassemblies.
You can use Window Select and the isolate the area of the assembly you want to work with
Open assemblies in light weight
Marie
Unread 26-02-2010, 20:26
angelawence11's Avatar
angelawence11 angelawence11 is offline
FRC #0195 (Cyber Knights)
Team Role: CAD
angelawence11 is an unknown quantity at this point
wayyy to many to count. haha if you include bolts and such we have well over 500
Unread 26-02-2010, 22:10
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
We currently have 2445 parts
FIRSTcast: How many people are there listening? Matt Krass General Forum 26 08-11-2005 19:00
How many students are on your team??? Pin Man Chit-Chat 26 02-04-2003 21:47
How many people are on your team? Alaina Chit-Chat 18 22-03-2003 21:48
How many people are on your team? Ken Delaney General Forum 31 07-12-2002 11:08
How many teams are there? archiver 2000 2 23-06-2002 22:45
