Go to Post The season ended. Not cool. - Koko Ed [more]
Unread 13-02-2010, 16:50
sp33chy sp33chy is offline
FRC #3332
sp33chy is an unknown quantity at this point
Stuttering compressor
Hello. I'm wondering if it is normal that when the compressor gets to 115-120psi it kind of does a small stutter instead of turning off completely (the pressure does not continue going up however).
The pressure relay switch seems to be on correctly.
Thanks.
Unread 13-02-2010, 16:55
hyperdude's Avatar
hyperdude hyperdude is offline
Techie.
AKA: Mike W.
FRC #2503 (Warrior Robotics)
hyperdude has a spectacular aura abouthyperdude has a spectacular aura abouthyperdude has a spectacular aura about
Re: Stuttering compressor
I'm no robot programmer, but I am pretty sure that you need to program the compressor to shut off when the pressure gets up to 120psi (when the relief valve opens). There's no way for the pneumatics system to "know" when it's at a certain pressure.
Now if you've already got this programmed, then you might want to post the code so someone can help you.
Unread 13-02-2010, 17:07
FRC #3332
I am coding in Java. Other than when instantiating the compressor, there is seemingly nothing else to do with the pressure relay switch ... or according to the API
Unread 13-02-2010, 17:32
hyperdude's Avatar
Techie.
AKA: Mike W.
I think that the pressure release valve (with the manual valve on the end) can be wired up so that once it reaches 120 and starts releasing pressure, it sends a signal to stop the compressor.
Again, I am not sure about this, but it's what I remember from what's been going on with our team the last two years.
Unread 13-02-2010, 17:38
No, that's not normal, unless you have a fast air leak.
Normally, the pressure switch goes on when the pressure drops below 95psi and turns off when it gets above 115psi. Then doesn't turn on again until it again falls below 95psi.
What does the gauge show?
Unread 13-02-2010, 17:39
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
If the compressor is staying on after 120psi, you will not pass inspection; this is not normal behavior.
Measure the resistance across the pressure switch. Does it toggle when the pressure reaches 120psi? (I can't remember if the switch is normally closed or open offhand) If not, you'll need to replace the switch.
As far as code goes, you should only need to instantiate the Compressor, I believe. It deals with itself after instantiation.
Aren't signatures a bit outdated?
Unread 13-02-2010, 19:44
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
The compressor will not operate until you first call the Start() method on it. Instantiation alone does not enable it.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 13-02-2010, 20:16
DonRotolo's Avatar
Back to humble
FRC #0832
No, you must use the pressure switch from the KoP to provide a signal to the cRio (via Digital Sidecar). That is the only electrical component that has the capability of signaling the system pressure for control.
Unread 13-02-2010, 21:11
hyperdude's Avatar
Techie.
AKA: Mike W.
Yup, that's it...
Unread 13-02-2010, 21:15
Isaac501 Isaac501 is offline
FRC #0501 (The PowerKnights)
Rookie Year: 1995
Isaac501 is just really niceIsaac501 is just really niceIsaac501 is just really niceIsaac501 is just really nice
This is incorrect. There is a pressure switch that (if properly calibrated) will signal when the pressure is at 120 PSI. wpilib has code which turns off the compressor when this signal is received. The compressor requires no intervention past properly wiring it and instantiating and start()ing.
Team 501 Academic Advisor, Systems Build Mentor
Unread 13-02-2010, 21:28
hyperdude's Avatar
Techie.
AKA: Mike W.
Yes, I know. I got confused over this, because I have never had to set up the pneumatics or programming.
Unread 16-02-2010, 18:54
FRC #3332
Hm. I am at a standstill then regarding it. I can manually stop and start the compressor with my code. Here is how I am instantiating it:
Compressor compress = new Compressor(1,1);
Here is my wiring: http://i49.tinypic.com/ixvxxl.jpg
http://i48.tinypic.com/23wltx.jpg
Anyone see anything wrong? Please help
Unread 16-02-2010, 18:59
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
Your wiring looks fine.
Have you measured the resistance across that pressure switch like I mentioned before? It is possible that your switch is defective. That switch should open (resistance jumping to infinite) when the air pressure reaches 115psi, and it should close once again (resistance jumping to 0) when the pressure drops below 95psi.
Unread 16-02-2010, 21:07
First thing, the red wire in the PWM cable connected to your switch needs to be insulated.
A little stutter is normal as the motor winds down against pressure. if it takes place for several seconds, it could be a noisey contact (rapidly turning on and off) within the switch.
Mark, might this also be a result of the same software issue with stuttering in other threads?
Unread 16-02-2010, 22:36
FRC #3332
The stuttering stopped by itself seemingly. I fed the watchdog a few more times in the code but I doubt that has anything to do with it, although it could and is worth mentioning. Maybe it was just because it was a new compressor?
Also thanks for catching the part about the uninsulated wire.
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
compressor maxgebhardt Pneumatics 14 17-01-2004 08:22
compressor Greg Needel General Forum 2 14-02-2003 07:50
Compressor TwoEdge47 Pneumatics 5 04-02-2003 22:41
Compressor agenova Programming 4 22-02-2002 21:44
