Go to Post They had a well made scouting form on the bottom was a check box with nothing next to it, when asked what the box was for they said. "Oh thats the jerk box" Since then one of our team goals is "Stay out of the jerk box" - Gary Stearns [more]
Unread 15-02-2010, 17:47
Twisted eric's Avatar
Twisted eric Twisted eric is offline
FRC #0581
Twisted eric is an unknown quantity at this point
Question Programming the teleop
My programming team are stuck
like the title says I'm tying to program I don't know what I'm missing
code
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Watchdog;
public class Demonized extends SimpleRobot {
RobotDrive drive = new RobotDrive(1, 2);
Joystick leftStick = new Joystick(1);
Joystick rightStick = new Joystick(2);
Watchdog Fenrir = Watchdog.getInstance();
public void autonomous() {
while(true && isAutonomous() && isEnabled())
for (int i = 0; i < 4; i++) {
Fenrir.feed();
drive.drive(0.5, 0.0); // drive 50% fwd 0% turn
Fenrir.feed();
drive.drive(0.0, 0.5);
drive.drive(0.0, 0.0); // drive 0% fwd, 0% turn
public void operatorControl() {
while (true && isOperatorControl() && isEnabled()) // loop until change
drive.tankDrive(leftStick, rightStick);
Timer.delay(0.005);
Fenrir.feed();
help will be much appreciated
team 581
Unread 16-02-2010, 16:04
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Programming the teleop
You need to "feed" the watchdog timer in the operatorControl() method. I'm not sure if that's what you're seeing, but I would expect that you are getting a "Watchdog not fed" message on the driver station.
Insert a Fenrir.feed() in the loop with the drive.tankDrive() call.
Brad Miller
Robotics Resource Center
Unread 16-02-2010, 17:26
FRC #0581
Thank you that was what i was missing any help with the pneumatic compressor.
Unread 16-02-2010, 18:18
FRC #0581
code
import edu.wpi.first.wpilibj.Compressor;
Compressor Siberian = new Compressor(1,1);
Fenrir.feed();
Fenrir.feed();
Timer.delay(0.005);
Fenrir.feed();
new code update
Unread 16-02-2010, 18:36
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
add a Siberian.start() to the outside of your while loop
Unread 16-02-2010, 18:53
FRC #0581
which wiled loop auto or tele op
OH
and can everyone help with sensing pressure and every thing first time using java.
Unread 16-02-2010, 18:57
1 * 4 != 14
Talking Re: Programming the teleop
i reccomend you make a setupRobot method for stuff like that.
insert the following inbetween the autonomous and teleop code
void setUpRobot() {
Siberian.start();
Fernir.feed();
then just add setUpRobot(); to your teleop and autonomous code.
That should fix it
Unread 16-02-2010, 19:10
FRC #0581
void setUpRobot() {
Siberian.start();
Fernir.feed();
That should fix it
Thanks
do you know how to sense pressure value and auto shut off
Thanks in advance and sorry for so-many questions.
Unread 16-02-2010, 20:11
1 * 4 != 14
Dude, its ok, i had the same questions.
it will automatically shut off as long as the wiring is correct (check the diagrams), so programming can now rest easy.
Unread 16-02-2010, 20:48
FRC #0581
in the pneumatics manual here (http://www.usfirst.org/uploadedFiles...%20Rev%20-.pdf)
says that there is no default program in the cRIO to control
the compressor power.
Unread 16-02-2010, 21:48
1 * 4 != 14
its always worked for us
Enable Teleop in Robot Main ThisAintJeff NI LabVIEW 4 04-02-2010 14:33
NXT Mindstorm Teleop EXamples johncap100 FIRST Tech Challenge 4 10-10-2009 09:48
problem with passing doubles back into the "TeleOp Execute" loop windell747 NI LabVIEW 1 21-03-2009 00:50
Teleop Lag Xavier Brandall Programming 14 17-03-2009 18:21
Detecting Start of TeleOp Mode Danny Diaz Programming 4 26-02-2008 01:37
