Go to Post Corrected, math isn't my strong point (I went to art school for a reason) - KelliV [more]
Unread 02-16-2010, 09:36 PM
urg8rb8 urg8rb8 is offline
FRC #0108
urg8rb8 is an unknown quantity at this point
Re: cRIO v20 Update Problems
Originally Posted by 1168Programmer View Post
As an addition, the output that we are seeing when we try to upload the code to the cRIO is as follows:
Connecting FTP @10.11.68.2
upgrade:
Sending local file image.suite
flashapp:
deploy:
init:
Waiting to connect to OTA command server of 10.11.68.2:8001 for past 11s
Waiting to connect to OTA command server of 10.11.68.2:8001 for past 12s
Waiting to connect to OTA command server of 10.11.68.2:8001 for past 13s
Waiting to connect to OTA command server of 10.11.68.2:8001 for past 14s
Waiting to connect to OTA command server of 10.11.68.2:8001 for past 15s
Waiting to connect to OTA command server of 10.11.68.2:8001 for past 16s
Waiting to connect to OTA command server of 10.11.68.2:8001 for past 17s
Waiting to connect to OTA command server of 10.11.68.2:8001 for past 18s
Waiting to connect to OTA command server of 10.11.68.2:8001 for past 19s
Waiting to connect to OTA command server of 10.11.68.2:8001 for past 20s
and it will continue to print the "waiting to connect to OTA command server" line until we halt it.
Any help is appreciated.
I had this exact same problem today after I reformatted and programmed the crio with v20. The only thing I did was reboot the crio to "fix" the problem. I have not seen that problem again since.
cRio problems blazingshadow Programming 2 01-31-2010 05:18 PM
cRio problems tanguma26 Programming 4 01-21-2010 09:09 PM
cRIO Firmware Update? Sauce Programming 10 01-19-2010 11:05 PM
cRIO update 3.0 problems Two-Face Programming 3 02-14-2009 10:06 AM
crio update file nickmagus Programming 1 11-28-2008 07:20 PM
