Go to Post 50 years from now, the FRC will still be waiting and hoping for a water game. That's my prediction. - TheBoulderite [more]
  #31   Spotlight this post!
Unread 13-02-2010, 20:01
PHSRobotics PHSRobotics is offline
FRC #2135
PHSRobotics is an unknown quantity at this point
Re: How to get the camera to show images on the dashboard?
Thank you for the link- One more question- So when one is going to change the compression to 20% they use the set compression vi, but then where do you establish the 20%? When it is made the constant there is no change. HELP PLEASE!!
  #32   Spotlight this post!
Unread 13-02-2010, 20:06
IF you set the compression in Begin, then you don't need to worry about what is stored on the camera. But I believe the question you asking is about when values are saved as defaults on the camera, and the answer to my knowledge is all modifications are saved. I don't know how often things are written to flash or flushed, but changes are persisted without any explicit steps.
Greg McKaskle
  #33   Spotlight this post!
Unread 13-02-2010, 20:44
cmh0114 cmh0114 is offline
AKA: Cam H
FRC #0217 (Thunderchickens)
cmh0114 will become famous soon enoughcmh0114 will become famous soon enough
Originally Posted by PHSRobotics View Post
Thank you for all the help- we figured out that our code was missing some crucial components that wasn't allowing us to obtain a camera image on the Dashboard.
I do have another question though- Our camera has quite a delay (about 1 second), does anyone know how to make this delay less or nonexistent?
Thank you!
If you create a custom Dashboard without the graphs on the right half, you can get a nearly live feed from the camera. One of our programmers found a modded Dashboard on CD somewhere; I'll get the link from him tomorrow or Monday and post it.
Also, I might be missing something, but I thought that the camera had to have a specific IP address -- 10.XX.YY.#, where XXYY is your team number (and # is just some random number). But it sounds like you keep setting it to 192.168.0.##. That might be giving you a problem with getting the feed.
  #34   Spotlight this post!
Unread 13-02-2010, 22:19
Quite incorrect.
Leave the camera with it's default IP of 192.168.0.90
Port 2 of the cRIO is setup for that network only.
  #35   Spotlight this post!
Unread 15-02-2010, 09:02
Also, I was not able to reproduce the solution with the charts. By changing compression, you can get high frame rates with the chart. By deleting the chart, the frame rates are still determined by the compression ... and a few other factors such as what is running on the cRIO, the load on the classmate or dashboard computer, etc.
Greg McKaskle
  #36   Spotlight this post!
Unread 16-02-2010, 13:55
vooboo13 vooboo13 is offline
FRC #3260
vooboo13 is an unknown quantity at this point
Sorry for reposting or anything, but can anyone help me with my question? We are very stuck and I have thread through a seemingly endless number of "camera doesn't work" threads with no luck.
  #37   Spotlight this post!
Unread 16-02-2010, 14:21
I'd try using the reset the camera by pulling the power, then holding the reset button while plugging the power back in and continuing to hold until you get the orange light around the lens.
Then running the Axis Setup utility again.
The camera won't feed the Dashboard until it's connected to the cRIO port 2 with a crossover cable (a pink one came in the KOP).
  #38   Spotlight this post!
Unread 16-02-2010, 21:43
FRC #3260
Thanks for the response Mark. So basically, reset the camera to factory settings, create a username of FRC:FRC, then plug it into the Ethernet Port 2 of the cRIO? I'll give that a shot.
  #39   Spotlight this post!
Unread 20-02-2010, 11:55
FRC #2135
Thank you from Team 2135! See you at the competition!
Lost the camera part of the dashboard... 1168Programmer FRC Control System 5 15-02-2010 10:30
yet another No Camera Images on Dashboard thread oddjob C/C++ 11 29-01-2010 20:53
Very Basic: Get a program running on the cRio that will show video on Classmat isaacdl Control System 6 23-01-2010 17:33
Where do I begin to get the robot to move using the camera? Ianuser Programming 10 16-02-2007 17:55
How do I get distance between Camera and the target? sjung9442 Programming 5 27-01-2006 09:44
