Go to Post It is crucial to keep experience and keeping collected under pressure as high points that can't be measured in a test. - jnelly [more]
  #31   Spotlight this post!
Unread 16-02-2010, 22:26
BradMello's Avatar
BradMello BradMello is offline
Broken Arrow
FRC #0078 (Rhode Rage & AIR Strike)
Team Role: Driver
BradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant future
Send a message via AIM to BradMello
Re: Team 78 AIR Strike Official Teaser. Climbing Included!
Originally Posted by JVN View Post
When you have one of the best coaches in FIRST, magic happens!
We've learned from the best, that's certain
  #32   Spotlight this post!
Unread 17-02-2010, 02:13
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
How easy do you expect it to be to line up your hanger with the bar?
It looks pretty sweet. Should be another good bot (as usual)
2001-2004: Team 100
2006-Present: Team 254
  #33   Spotlight this post!
Unread 17-02-2010, 09:12
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I had the same question too. Do you guys plan to do some sort of turn onto the bar and hook your mechanism on?
Other than that, it looks like an awesome machine. I really love the way is sits suspended, it looks almost like it's levitating.
-Dustin Benedict
  #34   Spotlight this post!
Unread 17-02-2010, 09:37
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
There is a gap between the drive and idler wheels. Our drivers are pretty adept at getting the pole in between the wheels. Drive forward a few inches and the rear (idler) wheel and front (drive) wheel both engage the pole. Hit the button and watch it drive up.
  #35   Spotlight this post!
Unread 17-02-2010, 09:38
BradMello's Avatar
Broken Arrow
Team Role: Driver
Check out this episode of American Robot, we demonstrate the concept of hooking onto the bar at around 3:45. It's slightly more difficult with the actual arm because the distance between the idler and drive wheel was reduced when we decided on a pneumatic wheel.
  #36   Spotlight this post!
Unread 22-02-2010, 09:52
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
FRC Video Review - Change is Coming
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Awesome video, I've seen a few teams using the same suction cup as your team for their vacuum ball control method, where did you find those?
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
  #37   Spotlight this post!
Unread 23-02-2010, 23:26
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
So the birth of team 78 has begun with a great looking robot.
Why did 121 form 78 ?
When you swing out the arm to hang, how does it lock without bending ?
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
  #38   Spotlight this post!
Unread 24-02-2010, 00:04
Rick's Avatar
Rick Rick is offline
Ready to STRIKE!
AKA: Rick Blight
FRC #0078 (AIR STRIKE)
Rick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond repute
Thanks for the compliment.
We are a brand new team, but with enough veteran mentors that we are not considered a rookie team under FIRST rules. Our organization works with 16 different schools in our community and has five (3 FLL, 1 FTC, 1 FRC) teams.
Here is a good pic of hanging: http://www.joemenassa.com/images/rob...816_large.html
For our entire build season in pictures see: http://www.joemenassa.com/robotics2010.html
Like Aquidneck Island Robotics on Facebook!
  #39   Spotlight this post!
Unread 24-02-2010, 00:51
D@ve's Avatar
D@ve D@ve is offline
Make it Happen
AKA: David Ferreira
FRC #0078 (Air Strike)
D@ve is a glorious beacon of lightD@ve is a glorious beacon of lightD@ve is a glorious beacon of lightD@ve is a glorious beacon of lightD@ve is a glorious beacon of light
Send a message via AIM to D@ve
I wanna thank the 78 crew of mentors and students for a great week 6. I unfortunately was not able to be there the 5 weeks prior. I just wanna say thank you. Thank you all for makeing this old veteran feel proud to be apart of your team. See you all at BAE
Dave
  #40   Spotlight this post!
Unread 25-02-2010, 15:31
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Did you folks try different distances between the idler and the drive wheel?
I am assuming that its better to make them closer together in order to wedge it in better for added friction, hence, the tradeoff being harder for the driver to set it in place on the tower pole.
If so, was it harder to climb the pole with a greater distance apart? From the pics, I cant calculate if there is added torque or not.
  #41   Spotlight this post!
Unread 25-02-2010, 15:59
neshera's Avatar
neshera neshera is offline
Nesher G. Asner
AKA: Nesher G. Asner
FRC #1625 (Winnovation)
Team Role: Parent
neshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud of
Definition of "coopertition":
Being impressed and thrilled with seeing how well your robot drives, kicks, handles the ball, and especially hangs; and at the same time being a bit frightened and worried about facing your robot someday in competition.
Great, great job!
Do not panic! All is well!
- Kevin Bacon in Animal House
  #42   Spotlight this post!
Unread 25-02-2010, 17:47
Adrienne E. Adrienne E. is offline
New Yorker turned Texan
FRC #0148 (Robowranglers)
Adrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond repute
Great job guys! As always an amazing machine from an amazing group of people. The video work as been great all season. As in previous years, I was always excited for the next American Robot episode. I wish I was going to be at BAE next weekend to see you guys in action. Guess I'm going to have to wait till ATL. Can't wait to see the machine, and all of you!
Adrienne Emerson
191 Alumni 2000-2002
229 Alumni 2003-2006
148 2009-Present
pic: Official Team 2264 Teaser vivek16 Extra Discussion 5 05-02-2010 16:50
pic: Team 39 robot climbing ramp Ken Loyd Robot Showcase 9 20-03-2006 04:05
Official Team 302 teaser pic Justin_302 Robot Showcase 0 09-02-2006 20:16
pic: Team 81 Official Teaser Eldarion Robot Showcase 24 09-02-2006 19:41
Strike deadline is Friday, will Major League Baseball Strike now? D.J. Fluck Chit-Chat 16 30-08-2002 12:07
