Go to Post So we dont need a brain to run the minibot? - TheGuyz [more]
Unread 16-02-2010, 23:51
Poke2201 Poke2201 is offline
AKA: Josh
FRC #0814
Poke2201 is an unknown quantity at this point
Re: Coding Relay with Compressor
Ok I made a new code in Teleop with solenoids and Relay and compressors I cant tell if I did this right, and I just followed most of the examples around here and LabView.
Images of Teleop:
Compressor On, Solenoids Extended
Compressor On, Solenoids Retracted
Compressor Off, Solenoids Retracted
solenoid with compressor vi ElanaC NI LabVIEW 42 29-12-2010 13:38
[OCCRA]: Problem with the compressor, pressure switch, or Bosch relay. BrittanyV OCCRA 3 16-10-2006 15:42
Help needed with coding simultaneous movement (EasyC/VEX) bodaciousllama Programming 7 14-08-2006 17:35
Problem with compressor Nick R. Pneumatics 3 21-02-2003 10:51
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
