Go to Post and as you can see, all rumor threads lead to silly, loads of silly - JaneYoung [more]
Unread 16-02-2010, 17:47
z.s.tar.gz z.s.tar.gz is offline
FRC #3242
z.s.tar.gz is an unknown quantity at this point
After updates windriver will not connect to cRIO
I ran the latest updates that were emailed out, and now I can not connect to the cRIO because I get errors every time.
I imaged it to the latest v20, and that's when things started going wrong. According to the error messages it has something to do with wpilib/vxworks conflicting with the new cRIO image.
Does anyone know how I can fix this or when I can get an older image?
Unread 17-02-2010, 02:47
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: After updates windriver will not connect to cRIO
Can you post the exact error message you are getting with copy and paste?
Unread 17-02-2010, 16:48
FRC #3242
Here is the first error message it gives:
     0x49e		0xaf		0x03
Stopping dump. Other errors might exist.
    Error: The systems running on the target and loaded into the target server memory are different.
Either wrong core file is selected on the host or text section is corrupted on target side.
Error during target server core initialization
Target Server will exit
The second error box does not allow copying and pasting.
Unread 17-02-2010, 16:52
You need to FTP the /ni-rt/system/vxWorks file from the cRIO and put it in the c:\windriver\WPILib\ directory.
-Joe
Unread 17-02-2010, 16:54
FRC #3242
ok I'll try it out
edit: thanks a ton! it totally works now!
for anyone who has the same problem, here's the new file:
Unread 17-02-2010, 17:08
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Originally Posted by z.s.tar.gz View Post
ok I'll try it out
It would be more useful if we could figure out how it came to be that you were able to image the cRio with the wrong kernel.
When I installed the latest Labview updates, the v19 stuff was deleted, replaced by the v20.
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Cannot connect to cRIO from WindRiver Darkknight512 C/C++ 8 25-01-2011 19:42
Cannot connect Windriver to robot abpahl C/C++ 4 19-02-2010 08:28
Can not connect to cRIO z.s.tar.gz Programming 2 13-02-2010 19:06
CRIO not working with Windriver dpeterson3 C/C++ 7 07-01-2009 20:49
Life After Dean: Who Will Lead FIRST After Kamen and Flowers?? Joe Matt General Forum 25 24-06-2002 00:12
