Go to Post As long as teams keep showing their consistency in innovation, FIRST will keep dazzling us all. - Amanda Morrison [more]
Unread 16-02-2010, 11:55
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
My mecanum method wont strafe
I wrote this after looking at some documentation someone wrote up.
    public void mechanumDrive(double v, double r, double s){
         * You all love Dr. Tran, so Try His mega-awesome MECANUM DRIVE!!!
        double FLval; double FRval; double RLval; double RRval;
        FLval = v - r - s;
        FRval = v + r + s;
        RLval = v - r + s;
        RRval = v + r - s;
        FLjag.set(FLval);
        FRjag.set(FRval);
        LRjag.set(RLval);
        RRjag.set(RRval);
        /*if (leftStick.getRawButton(2)) {
            v = v * Math.sqrt(2.0);
            double dirInRad = (s + 45.0) * 3.14159 / 180.0;
            double cosD = Math.cos(dirInRad);
            double sinD = Math.sin(dirInRad);
            FLval = sinD * v - r;
            FRval = cosD * v + r;
            RLval = sinD * v + r;
            RRval = cosD * v - r;
            FLjag.set(FLval);
            FRjag.set(FRval);
            LRjag.set(RLval);
            RRjag.set(RRval);
    void rawStrafe(String direction, double speed) {
        direction.toLowerCase();
        if (direction.compareTo("left") == 0) {
            FLjag.set(-speed);
            FRjag.set(speed);
            RRjag.set(-speed);
            LRjag.set(speed);
        } else if (direction.compareTo("right") == 0) {
            FLjag.set(speed);
            FRjag.set(-speed);
            RRjag.set(speed);
            LRjag.set(-speed);
I cannot get either if these to strafe. what happens when I try is the wheels "stick" in place (thats about the best way I can describe it)
Unread 16-02-2010, 15:55
AKA: Brad
#0190 ( Gompei and the Herd)
Re: My mecanum method wont strafe
There is a macanum drive method built into the RobotDrive class in WPILib. If you create a RobotDrive object with the port numbers for the 4 SpeedControllers, you can call the holonomicDrive method that takes a direction (X and Y value) and a rate of rotation. There are a number of teams that are using that code and it seems to be working for them.
If you would like to write it yourself, feel free to check out the source code for that class. The math is pretty well tested.
Brad Miller
Robotics Resource Center
Unread 16-02-2010, 16:34
1 * 4 != 14
the holoNomic Drive function wont let my robot go forwards
Unread 16-02-2010, 17:13
AKA: Brad
It's designed for 4 macanum wheels toed in 45 degrees. Is that what you have?
Here are the comments for the holonomicDrive method:
     * Holonomic drive class for Mecanum wheeled robots.
     * Experimental class for driving with Mecanum wheeled robots. There are 4 wheels
     * on the robot, arranged so that the front and back wheels are toed in 45 degrees.
     * For holonomic drive with omni-wheels, the rotation value will need to be
     * offset based on the drive configuration.
     * @param magnitude The speed that the robot should drive in a given direction.
     * @param direction The direction the robot should drive in degrees. The direction and maginitute are
     * independent of the rotation rate.
     * @param rotation The rate of rotation for the robot that is completely independent of
     * the magnitute or direction.
Brad Miller
Unread 16-02-2010, 17:58
1 * 4 != 14
We have the wheels as such (birds-eye view):
(from bottom)
Unread 16-02-2010, 19:26
Daedalus Daedalus is offline
Daedalus is an unknown quantity at this point
(from bottom)
You need to switch your wheels. The bottom view should look like your top view currently does. That should fix your problem, the reason your robot will not work right now is because the force vectors are incorrect and will prevent your robot from moving.
Unread 17-02-2010, 02:51
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Actually he has it correct and you are recommending that he make it wrong. The bottom should be a diamond.
Unread 17-02-2010, 13:18
1 * 4 != 14
then we spent an hour switching the wheels for nothing?
Unread 17-02-2010, 14:04
It would seem so. It appears that is the only post that user account has made. Perhaps if you had searched you would have seen this thread or this thread or this thread.
Searching is your friend... you don't have to wait for a reply and others don't have to keep answering the same questions.
-Joe
Dashboard wont work... nadavsen2 C/C++ 2 22-09-2012 15:43
SIGNAL LIGHT WONT WORK kick3nitx360 Electrical 57 18-02-2010 22:36
Team 930's bump strafe Brewerboy82 Robot Showcase 23 08-02-2010 19:35
cRIO wont run software ThisAintJeff NI LabVIEW 4 02-02-2010 15:47
G4 wont turn on! MattK General Forum 14 26-08-2003 09:44
