Go to Post One of those things I learned in kindergarten - never introduce myself to an “enraged” woman wielding a clipboard. - Mark McLeod [more]
Unread 17-02-2010, 06:17
Swens's Avatar
Swens Swens is offline
AKA: Robert Swensen
FRC #2892 (Hottie Botties)
Swens can only hope to improve
Question Heat.
I'm going through the forums and seeing a lot of tunneler bots. By having a tunneler the chances are pretty good that your electronics and cRio are going to be very tightly packed. My question is if anyone has had concerns or issues with overheating on the robot in the past. I'm just asking to get a feel for how much heat these bots can generate. I'm apart of a teem for the first year this year and would appreciate and feedback.
Climb tree.
You climb the tree.
Climb down tree.
I do not understand down.
Jump out of tree.
You jump out of the tree killing yourself.
*Game Over*
-Zork
Unread 17-02-2010, 07:47
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
Re: Heat.
I'm not sure if teams need to be too worried about electronics overheating.
For me, I'm more worried about our motors pulling too much and tripping the breaker, and heating up in the process of it.
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 17-02-2010, 08:02
Re: Heat.
Robert,
There are a few areas where heat can be a problem. The circuit breakers are designed with bimetallic parts that when heated deform to open the circuit breaker. The FP and window motors also have thermal breakers built into their case to prevent damage to the motor. There is likely more of an issue with the devices running at elevated temperatures than anything else. Should a team design cause high currents in the motors, then the Jaguars/Victors will experience elevated temperatures, but they have fans attached. Keeping those fans unobstructed is essential. Finally, high currents, the type often encountered with tank turns on carpet without omni wheels, result in breakers tripping. The more often the trip the higher the temperature. It is not uncommon for breakers that trip under these conditions, to do so rapidly. This results in a very hot breaker. Please be careful when working around the PD right after a match.
The Crio and side cars are pretty robust so I don't think that will be an issue.
Unread 17-02-2010, 16:52
Swens's Avatar
AKA: Robert Swensen
Re: Heat.
Thanks for the advice.
Climb tree.
You climb the tree.
Climb down tree.
Jump out of tree.
*Game Over*
-Zork
Unread 17-02-2010, 17:16
Dancin103 Dancin103 is offline
The Crazy Blonde
AKA: Cassie
FRC #0103 (Cybersonics)
Dancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond repute
Send a message via AIM to Dancin103
Re: Heat.
We'll in my 15 years of FIRST, I have seen about on average 2 bots a year catch on fire due to electrical issues. In the past we have had CIMs get hot and we figured a way to cool them down, we found a coolant spray at RadioShack. Usually it's not that problematic. You're given enough time to "cool down" in between matches and such. If you have any problems let us know.
Cass
Cybersonics Technology Team 103
2003 Championship Chairman's Award Winners
NEED CHAIRMAN'S HELP?? Subscribe to our YouTube Channel, we answer your questions daily!
Unread 17-02-2010, 17:18
Smoores's Avatar
Smoores Smoores is offline
AKA: Steve Moore
FRC #2272 (Metalheads)
Team Role: Student
Smoores will become famous soon enoughSmoores will become famous soon enough
Re: Heat.
just as long as you keep it FAR away from the compressor it seems fine. (or is it abnormal that our compressor will burn things to the touch?)
Aviation in itself is not inherently dangerous. But to an even greater degree than the sea, it is terribly unforgiving of any carelessness, incapacity or neglect.
2007 Championship Highest Rookie Seed - Galileo
2007 CA Rookie All-Star
2007 CA Highest Rookie Seed
Unread 17-02-2010, 17:39
Re: Heat.
Steven,
We are anticipating that teams with a lot of pneumatics will be running the compressor for long periods of time. Compressing air does cause heat. The head of the compressor will become hot to the touch during a match. Be careful!
Unread 17-02-2010, 17:48
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Heat.
While we plan on going over the bump and avoidig the tunnel, almost all of our robot is under 17.5 inches. Yes, everything is really packed in there. When we make the hood for the top of the robot, we'll have holes drilled to line up with the victor and spike fans to help keep them cool. If that's not enough (and we're almost sure it will be with our design), we can always add some of the muffin fans from the KOP to help out as well.
Heat Sensor irishninja Kit & Additional Hardware 6 24-04-2006 08:58
Cold heat? Billfred Chit-Chat 27 15-03-2006 19:01
motor heat EMS Motors 7 18-05-2005 13:52
heat sinks archiver 2000 1 23-06-2002 22:45
heat gun Lake Orion OCCRA 2 21-10-2001 23:34
