Go to Post I want to understand the physics. - Molten [more]
Unread 15-02-2010, 08:34
Rikard023's Avatar
Rikard023 Rikard023 is offline
Programmer/Animator/Captain/Ninja
AKA: Rikard
FRC #0522 (The Robowizards)
Rikard023 is an unknown quantity at this point
Send a message via AIM to Rikard023
How to write Notifier help!!
OK im trying to write a notifier class to cause a delay in my program where one task would be preformed after another with a specific delay.
I get to the part where i named what the notifier is but when the little box appears after i put the name then -> the box says
Notifier(TimerEventHandler handler, void *param)
Now i dont know whatvalues to put in or what any of this means
Any documentation or code any one could give me to simply write a notifier would be much appreciated
"Sharp edges are prone to cause bleeding trust me i know" T.T
http://www.robowizards.com
Unread 15-02-2010, 10:07
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Re: How to write Notifier help!!
I'll post some help later tonight.
Unread 16-02-2010, 23:33
slavik262's Avatar
AKA: Matt Kline
First you write a function that does whatever you want to do after the notifier delay. Say you want to activate a solenoid after the delay. The Notifier calls a function that takes a void pointer as an argument. We'll pass it a pointer to our solenoid and cast it back in the function so we can use it.
Here's the function:
void SolenoidDelayEventHandler(void* param)
        //Cast the pointer back to the solenoid type
	Solenoid* sol = (Solenoid*)param;
        //Activate the solenoid
	sol->Set(true);
Now, when we create our Notifier class, it wants two arguments: the function and what to pass to the function. We create it like so:
//As a member of your robot class,
Notifier solenoidNotifier;
//Then in the constructor of your robot class
solenoidNotifier(SolenoidDelayEventHandler, &mySolenoid)
//assuming mySolenoid is declared statically in the robot class as well
//and not with the keyword new
Now whenever you want to call your notifier function (and therefore activate the solenoid) after a delay time, just call
solenoidNotifier.StartSingle(time);
where time is the delay time in seconds. There's also a StartPeriodic(time) function in the Notifier class that calls the function continuously, where time is the delay between calls. It stops when you call Notifier::Stop().
Any questions?
Unread 17-02-2010, 05:01
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Originally Posted by slavik262 View Post
Any questions?
Yes.
I just downloaded the WPILibSource20100107.zip because I am curious how they implemented the notifiers.
Is that the latest library source from WPI as far as you know?
THX!
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 17-02-2010, 08:40
slavik262's Avatar
AKA: Matt Kline
Originally Posted by gvarndell View Post
Yes.
THX!
Off the top of my head, I don't know the current version number and I can't download the newest update to check since I'm at school at the moment.
As far as how notifiers work, they seem to work on an interrupt level (I'm assuming through a hardware timer run in the FPGA). This is just a guess from glancing over the header file; anyone can feel free to confirm or correct me here.
Unread 20-02-2010, 07:56
Rikard023's Avatar
AKA: Rikard
I still need help with the notifier if anyone else has info
kinda close to ship date
Unread 20-02-2010, 08:12
Rikard023's Avatar
AKA: Rikard
Yes.
THX!
And the last workbench update is WorkbenchUpdate20100217.exe
http://first.wpi.edu/Images/CMS/Firs...te20100217.exe
how to write a good proposal and sponsorship letter for a event alanelf Fundraising 17 03-05-2011 06:58
Notifier fixes (impacting PIDController) heydowns C/C++ 0 05-02-2009 11:06
Notifier Class Phoenix Spud Programming 0 26-01-2009 20:16
How long to understand camera and write useful code RGuindon Programming 3 16-12-2007 01:37
How to write image data to binary PGM file format(P5)? tommy_chai Programming 0 08-10-2007 08:22
