How to configure the cRIO with windriver?
How exactly do you set up the cRIO with windriver? I followed the guide in /docs/frc and I did some googling, but the cRIO still won't connect.
I've heard that I need to reimage the device, how exactly would I do that? |
Re: How to configure the cRIO with windriver?
did you look on this page: http://usfirst.org/roboticsprograms/....aspx?id=10934
the one you need is section 2.6 (page 31) of http://usfirst.org/uploadedFiles/Com...ed-Rev-0.7.pdf |
You must use the labview Imaging device.
You set it to windriver C++ when you use it. This is how we did it. It is a completely different thing from labview. |
On that note, there's a new cRIO image out (vesion 20). Make sure you image your robot with that and not the old version 19. To get it, download and run the newest LabVIEW update. |
| How to connect the Workbench with the cRIO? | kentschool | C/C++ | 3 | 12-28-2009 04:03 PM |
| How do you run the pneumatics through the CRio w/o using the Jaguars and the Spikes | brreadd | Pneumatics | 3 | 11-20-2009 03:35 PM |
| Windriver connection to cRio | avolkov | Programming | 6 | 05-05-2009 08:40 AM |
| Running the Motors Backward in WindRiver & cRIO Freezes | kyungjin | C/C++ | 15 | 02-08-2009 02:24 PM |
| CRIO not working with Windriver | dpeterson3 | C/C++ | 7 | 01-07-2009 08:49 PM |
