Go to Post Consider yourself mentored, you have learned a lesson: "Don't stick your hands in icky things." - Amanda Morrison [more]
Unread 17-02-2010, 11:51
Itamar's Avatar
Itamar Itamar is offline
FRC #1943 (NeatTeam) & FRC #4590 (GreenBlitz)
Itamar is an unknown quantity at this point
Using 9 motors on the robot
We need to connect 9 motors this year
and as you know there are only 8 40A outputs on the POWER DISTRIBUTION BOARD.
we wanted to know wether we can connect one victor to a 30A output.
We want to know if it will work and if it is legal.
if we cannot do this
we would love to get a suggestion how to connect the 9th motor.
Thank you.
Unread 17-02-2010, 11:53
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Using 9 motors on the robot
Look at the power requirements for the motors. Only the CIMS and the Fisher-Price motors require 40 Amp breakers; the rest can use the 30 Amp connections.
Good luck!
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 17-02-2010, 11:55
Itamar's Avatar
Thank you for the quick answer!
We realy appreciate it.
Good luck to you too, and thank you once again.
Unread 17-02-2010, 11:59
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Thank you.
Take a look at the wiring rules. Depending on which motors you are using, they are required to be protected by a certain breaker.
<R46>
All active Power Distribution Board branch circuits shall be protected from overload with an appropriate value auto resetting Snap Action circuit breaker (from the KOP or identical equivalent).
A. Each speed controller branch circuit must be protected by one and only one 20-amp, 30-amp, or 40-amp circuit breaker on the Power Distribution Board. No other electrical load can be connected to the breaker supplying this circuit.
B. Each Spike relay module branch circuit must be protected with one and only one 20-amp circuit breaker on the Power Distribution Board. No other electrical load can be connected to the breaker supplying this circuit.
EDIT: Beat to response. Slow internet connection, I thank you.
Unread 17-02-2010, 12:09
Are you sure about that? I looked at this year's rules, and could not find any requirement that a CIM or a fisher price require 40 amp breakers. Best I could tell, any motor can use any size circuit breaker, as long as the wire was sized properly.
For example, a fisher price motor can draw more then 40 amps at stall, but it will also burn itself up at stall. It may be wise to use a smaller breaker.
Unread 17-02-2010, 12:14
Racer26 Racer26 is offline
You are indeed correct. The circuits on 20, 30, and 40 amp breakers must have appropriately sized wires, but there are not, as in the past, requirements that CIM's and FP's get 40A, and everything else is 20/30A.
Unread 17-02-2010, 12:48
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Good luck!
Not quite true, this year.
<R55>
A. Each CIM motor and Fisher-Price motor must be connected to one and only one approved speed controller. These motors must not be connected to relay modules.
<R46>
That being said... those two motors are the most likely to need a 40A breaker, as they can exceed 20/30A breakers safely - especially the CIM's. The other motors you can use smaller breakers without worrying too much about tripping them under normal, safe use.
Unread 17-02-2010, 14:05
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Don't forget <R52> that says you can have a max of 5 CIM motors:
D. One, two, or three additional 2½” CIM motors (part #FR801-001 and/or M4-R0062-12) in addition to those provided in the KOP. This means that up to five, and no more, 2½” CIM motors can be used on the ROBOT.
So at least four motors are not CIMS?
Brian K
Team 1225 Robotics Mentor
Unread 17-02-2010, 14:11
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Thank you.
poor battery
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 17-02-2010, 14:20
Mentor, LRI, MN RPC
Originally Posted by DarkFlame145 View Post
poor battery
The depends on how the motors are used. We have 8 motors on our robot this year (9 if you include the servo )
4 for driving, just like every other year
1 for a "ball magnet" like other teams have discussed and shown here, rolling continuously.
2 for a kicker - each one only needs to complete 1 full revolution out of the gear box per kick.
1 for a lifter which will only be used for 5-10 seconds at the end of the match.
So, a lot of motors to do a lot of different things... but overall not any more battery intensive than any other year.
Unread 19-02-2010, 08:26
Everyone,
The electrical rules are written to coordinate breaker size to wire size only. The breakers are sized to protect the wiring and nothing else. If you put #18 wire with a 40 amp breaker and something shorts, then the wire will set itself on fire. 40 amp breakers get #12 or larger, 30 amp breakers get #14 or larger and 20 amp breakers get #18 or larger.
You can run a 20 amp breaker for a CIM motor if you so choose. Both the Jaguar and Victor can handle currents in excess of the stall current of the CIM motors. The circuit breakers used on FRC robots have trip characteristics that allow currents in excess of 600% of the trip point for a few seconds. Yes, that is 240 amps for a 40 amp breaker.
Although the rules allow it, I can't see any reason why you would want to run any motor except the CIM or Fisher Price motors with a 40 amp breaker. For a maximum motor count of 5 CIM and 2 FP, that is only 7 40 amp breakers.
How many motors are you using on this years robot? VanMan Motors 47 02-02-2009 15:48
Using the IR remote to send radio commands to the robot Mikhail_Pham Control System 2 14-01-2008 00:14
Using two motors in the tandem Tom Line Motors 11 20-03-2007 09:20
Where do I begin to get the robot to move using the camera? Ianuser Programming 10 16-02-2007 17:55
Is Anyone Using Motors to Hoist themselves off the platform on the bar? xxlshortys Motors 36 25-02-2004 01:06
