Go to Post JVN, Captain Mechanical Engineer, Mr. "Software is evil", has supported the CMU camera. I'm speechless. What's next? Copioli designing in imperial? - Karthik [more]
Unread 17-02-2010, 12:18
alum1880 alum1880 is offline
FRC #1880
alum1880 is an unknown quantity at this point
Help on the Drive train!!!!
My name is Nick James and im from Team 1880. I do programming and I help with the robot.
The problem: The left side of our robot doesn't want to drive backwards, but we can drive forwards with both sides.
We tried:
-changing the motors
-changing the jaquars
-changing the PWM cables
-checking the program
-checking the wiring
-changing digital sidecar
-making sure the gearbox runs(with a battery as a direct source)
We are stumped at this point. If anybody knows or has any suggestions, please post!!!!
Thank You and hope to see everybody at the competition!!!!
Good Luck!!!
Team1880
Unread 17-02-2010, 12:23
Electrical Engineer
Rookie Year: 1995
Re: Help on the Drive train!!!!
I am 99% sure that your issue is software. Can you post your code?
Mike Betts
As easy as 355/113...
Unread 17-02-2010, 13:51
The Jaguar speed controller also has a failure mode where it only works in one direction. You could swap pwm cables between sides and see if the problem follows the pwm cable or the speed controller.
Unread 17-02-2010, 21:42
We had a similar symptom on our robot several years ago. The root cause was a loose bearing that let the gears disengage when the gearbox was running in one direction. Is your problem that the left side motors don't run in reverse, or that the left side wheels don't move when the motors turn that way? If the motors don't run, can you hear them trying to?
The Drive Train Question. whytheheckme General Forum 5 16-01-2010 21:56
Drive Train Components: the inner working parts of a drive train naruto137 Technical Discussion 3 10-12-2008 21:14
Help with drive train superbeano2004 Motors 23 01-02-2005 19:30
pic: team696 teaser of the Drive Train. xKLzKobE08x Extra Discussion 16 30-01-2005 22:59
Another chapter in the drive train story AdamT Technical Discussion 19 29-09-2002 13:52
