Go to Post DEKA is right next to the river, and when i got there this morning they wouldn't let us into the building, but apparently there is and standing water on the first floor. The ironic thing is that i work on the water project and we can't deal with a bit of water on the floor - Greg Needel [more]
Unread 17-02-2010, 12:37
TPNigl TPNigl is offline
FRC #0069 (Team HYPER)
TPNigl is an unknown quantity at this point
Victors not working with other code?
Ok, so we've got a lot of stuff working. However, we also have a problem. We're using java, and we have the robot drive defined and working fine. However, when we try to introduce code that simply controls the victor to activate the motor, not only do they not work, but the robot drive no longer works. Here's our declaration:
        m_robotDrive = new RobotDrive(1, 3, 2, 4);
        vctrCtrWheelLift = new Victor (5);
        vctrKickerMotorFront = new Victor (6);
        vctrKickerMotorRear = new Victor (7);
        vctrArmMotor1 = new Victor (8);
        vctrArmMotor2 = new Victor (9);
And here is the code we're trying to get to work with the motors being solely by the victors:
if (jStickDriveLeft.getRawButton(1) && !prxCtrWheelUp.get())
            vctrCtrWheelLift.set(1.0);
        else
            vctrCtrWheelLift.set(0.0);
        if (!jStickDriveLeft.getRawButton(1) && !prxCtrWheelDown.get())
        else
Any suggestions?
2011 Pit Crew:
2011 CT Xerox Creativity Award
HYPER Alumni
Unread 17-02-2010, 21:27
Re: Victors not working with other code?
prxCtrWheelUp has no effect in this code fragment. Do you really want vctrCtrWheelLift to run full speed forward only when the left joystick trigger is pressed and prxCtrWheelDown is false, and to stop otherwise?
Unread 17-02-2010, 21:46
Yea, we do. But we got it to work and it's fine. Thanks anyway!
2011 Pit Crew:
HYPER Alumni
code not working killerofall NI LabVIEW 5 18-02-2010 06:19
Solenoid code not working ssmith2 NI LabVIEW 6 03-02-2010 10:11
C++ Sample Code not working... hm29168 CAN 5 27-01-2010 20:59
Incrementation Code not working benhulett Programming 6 12-02-2007 17:39
Camera code not working.... DemonYawgmoth Programming 5 11-02-2006 09:21
