Go to Post There's no better way to start your FIRST career then opening a box and getting free stuff from Andy Baker! - JosephC [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 16-02-2010, 21:31
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
Jaguar Reset to Address 1
Programming language is java; using the serial bus to connect to the black jag; six motor controllers installed with ids 10, 11, 12, 13, 14, 15. Robot is driving fine. Put robot back on the cart, and attached camera wiring. Robot would not run anything. Exception thrown from Jaguar init function when constructing the CANJaguar class. Disconnected serial bus from cRIO and attached to pc. Ran the comm application. Now had ids 1, 10, 11, 13, 14. Turns out that two jaguars had "forgotten" their id and reverted to 1. First jag to be initialized was 11, but init of 11 would throw the exception. My best guess is some sort of "static discharge" event, although I cannot say for sure that one occured. Any other ideas?? I would hate for this to happen in the middle of a match.
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
Unread 17-02-2010, 11:35
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
Re: Jaguar Reset to Address 1
We had exactly the same thing occur last night. One of the grey Jags reset to ID 1 during a battery change. I'm also assuming a surge or static event, but it's concerning.
Unread 17-02-2010, 11:37
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
Yes, both of the ones which reset on us were the old style.
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 3806 2010
Unread 17-02-2010, 12:41
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Same thing happened here. Was doing a test drive, noticed one side of the bot was slower than the other and one of the jags was blinking yellow. I have absolutely no idea what caused the reset. I originally thought I had just missed that jag in the original setup of the bus, but now that other people had this problem I think it wasn't just me.
btw when you setup the jag that reset did you daisy-chain to that one from the black jag? I remember the one that reset was the only one we didn't have a cable long enough to reach from the black jag, so I had another grey one on the bus.
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 17-02-2010, 13:08
MikeE's Avatar
no team (Volunteer)
As long as only one Jag reset to 1, then daisy chaining works. We had it happen twice yesterday, once earlier in the day when the students were working with the robot (I was a little sceptical of the report at first) and also later in the evening when I saw it with my own eyes.
Unread 17-02-2010, 15:22
AKA: Ian Thompson
Out of curiosity, what are the IDs of the Jags that reset? Our's was 6.
Unread 17-02-2010, 16:05
MikeE's Avatar
no team (Volunteer)
IIRC it was 10 or 11.
Unread 17-02-2010, 17:44
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
For those of you who are having this problem. Are you able to recreate it reliably?
Does it happen during a specific window of time during robot operation?
Just to be clear, has ID resetting only been seen on Gray Jags?
If you are able to recreate the problem reliably, what do the Jaguar LEDs do before, throughout, and after the event that causes the ID to reset?
I am trying to figure out if this could possibly be a software problem. For example, could the CRIO be sending out a rogue Assign ID command?
Your help is greatly appreciated!
-David
Unread 17-02-2010, 19:21
AKA: Ian Thompson
As I remember, I had set the IDs and tested the system, and then the electronics board was mounted on the bot. There was never any power to the system until we powered on to download new code and test the bot. When the robot was used for the first time, the jag had been reset.
In terms of the LED, the only thing I noticed was a blinking yellow
Unread 18-02-2010, 02:37
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
-David
On my little test board, i have 5 black jaguars and 2 gray jaguars.
Bl-Bl-Bl-G-Bl-G
2 3 4 5 6 7
I have been able to reproduce this twice.
The first time, the power to the bus was off for about 6 hours. The Gray jag with ID 7 reset itself to 1.
The second time, the power was off for slightly more then a day.
This time, both gray jags set themselves to ID 1 leading to an interesting time trying to re-assign IDs.
Upon power up, the jags just blink yellow happily, no weird blinks.
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Last edited by biojae : 18-02-2010 at 02:39. Reason: Brown change to gray, they look Brown!
Unread 19-02-2010, 01:00
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
We had two Jaguars reset this evening. We attributed it to anamolies related to the recent updates where everything had to be updated including the cRio. This meant that the serial jaguar driver was removed. We've restored everything now.
Both the Jaguars that reset were gray. We only have one black.
We will certainly be keeping an eye on this problem. I have high hopes for CAN but the problems we are seeing are a bit disconcerting.
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
Unread 19-02-2010, 13:27
AKA: David Yanoshak
Hi all,
We just uploaded new Jaguar firmware (89) that should address this problem.
Please check this thread out:
http://www.chiefdelphi.com/forums/sh...d.php?p=923925
-David
Black Jaguar Not Taking New Address duane CAN 1 06-02-2010 19:55
Camera won't initialize when reset from RC - reset from OI and Power-up works, krunal Programming 7 15-01-2007 00:13
Address archiver 2000 0 23-06-2002 23:22
Address archiver 2000 2 23-06-2002 23:22
