Go to Post Math is always fun, especially when it's useful. - Guy Davidson [more]
Unread 02-17-2010, 01:31 PM
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
Re: Compressor Code
Originally Posted by Robopanda6 View Post
We've tried using samples of compressor codes from other teams that said their code works correctly but when we try to run our code it runs correctly but our compressor isn't turning on. Could i see other codes or does anyone have any suggestion?
It would be very aprecciated.
I don't know if this will help, but we have had several team members "correct" the wiring by moving the pressure sensor input or relay output to the PWM connectors.
The pressure sensor should be wired to the DIO pins and compressor spike relay to one of the relay outputs on the digital sidecar (and obviously the physical wiring needs to match the channel numbers in the code).
Bizarre issues with compressor code Rafael Vasquez Programming 2 02-10-2010 10:26 PM
Compressor Code causes No Robot Code Error sircedric4 C/C++ 25 02-03-2010 10:13 AM
Automated Air Compressor code ShotgunNinja Programming 12 02-14-2008 03:52 PM
Compressor Code gacp Programming 2 02-19-2005 04:18 PM
Help With Compressor Code fred Programming 6 01-21-2005 05:40 PM
