Go to Post what would we do without brandon? - Arefin Bari [more]
Unread 17-02-2010, 10:33
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
How are they going to inspect for a 3" incursion
Anyone know how they are going to determine that the soccer ball goes into your robot 3 inches? The ball is made up of sown together sections so it can vary in depth.
One of our engineers found that a regualtion bowling ball is the same size as the soccer ball. Hmmmmmmmm
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 17-02-2010, 13:07
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: How are they going to inspect for a 3" incursion
Ssshhhhhhh! We are not supposed to worry about bowling ball incursion until next year.
-dave
Unread 17-02-2010, 13:24
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
This is just my opinion, but it would be easiest to have a standard regulation ball at inspection so the inspectors can check that, on a flat ground just sitting there, a ball can't go more than 3 inches in. Yes, the ball won't be perfectly round, but it should be close enough... If the inspector sees any trouble spots, he can first warn the team, and second warn the refs. Then the refs just need to watch those trouble spots and for any obvious problems (like teams coming over a bump and landing on top of a ball).
It's going to be impossible for a ref to determine on the fly if your robot allows a 3 inch incursion under normal conditions - that determination almost has to be done off the field.
Unread 17-02-2010, 13:27
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Usually they use a jig. I would guess a simple square tube with a 3 inch piece screwed to it. Then they'll slide the bar back and forth to check the areas.
Unread 17-02-2010, 13:35
Racer26 Racer26 is offline
-dave
aw crap. here we go again....
Unread 17-02-2010, 13:38
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Off the field becomes tricky. It is not against the rules for a ball to be able to roll more than 3" under your robot, it is only against the rules for a ball to roll 3" under your robot.
And I agree that the best way to do this is to have the inspectors notify the referees of the possibility of the ball rolling 3" or more under your robot.
___________________
- Tennyson, Ulysses
Unread 17-02-2010, 13:41
Onward through the fog.
Don't worry, the game piece will never be a bowling ball. They are too hard to wear.
~ Helen Keller
(1880-1968)
Unread 17-02-2010, 13:44
Mad Scientist
AKA: Me
FRC #2040 (DERT)
You are going to be wearing soccerballs?
___________________
- Tennyson, Ulysses
Unread 17-02-2010, 13:45
I'm not but I'm sure someone will think of something. I'm sticking with my cool Converse and tie-dye.
~ Helen Keller
(1880-1968)
Unread 17-02-2010, 13:53
How "un-round" are soccerballs? Are we arguing over thousandths of an inch? Hundreths? Tenths?
Unread 17-02-2010, 13:54
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
My interpretation matches yours. This is not an inspection issue, it is a referee "real time" issue similar to extending outside the max extension in 2008.
I think 148 is going to make a point of demonstrating to head-refs that balls cannot enter our robot more than 3". Education may be the key to avoiding penalties from over-eager flag throwers.
I can only imagine the reaction from our new coach if we get such a penalty...
-John
Unread 17-02-2010, 14:01
EricH EricH is online now
Daniel and John, <R19> clearly specifies that the robots must be designed so that the balls cannot go more than 3" inside the frame perimeter during normal operation.
This then becomes an inspection issue, because the inspectors need to check the normal operation parameters for the 3" incursion, whether or not it happens on the field.
I'm thinking that a rig like the inspectors had last year for the bumper/trailer hitch checking would probably do the trick. One side bumper, one side ball. If it catches something, grab a ball from the practice field or the field stash to verify.
Unread 17-02-2010, 14:03
RoboMom RoboMom is offline
people expediter on Team Kluge
AKA: Jenny Beatty, no relation
no team (they are all my teams)
RoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond repute
I'm wearing soccer balls. Well, sort-of. (already posted in cdmedia)
And I've upgraded to glitter Converse this year.
Co-Founder of NEMO (Non-Engineering Mentor Organization) www.firstnemo.org
Volunteer Director, STEMaction, Inc. www.stemaction.org
FIRST Senior Mentor: Nov. 2004 to June 2009: "Experience is that marvelous thing that enables you to recognize a mistake when you make it again"
This is How I Work: http://www.chiefdelphi.com/media/papers/2862
Unread 17-02-2010, 14:04
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
I'm curious about what the refs are going to do if a ball fence on a robot gets bent or tweaked during competition and lets the ball in, say, 4 inches. They would have a hell of a time seeing that from 30 feet away...
Unread 17-02-2010, 14:09
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
-John
New coach??? Who is that going to be???
2012-2016 Wave Robotics Team 2826
For some reason our motors are "breaking" and not going forward. Why? Bensky Programming 3 25-01-2008 13:39
Why are they showing us how to build a chasis? Leav Technical Discussion 16 10-01-2005 00:29
How are they going? Mullet Chairman's Award 2 01-02-2003 15:13
When are they going to finish the FIRST EDUrobot- a primer for success website? team222badbrad Robotics Education and Curriculum 0 28-12-2002 19:10
