Go to Post FIRST is the best thing that has ever happened to me...FIRST has taught me so much more than anything I learned in the classroom. The thing with my team, is we are so close, we are family, and I have figured out so much about who I am because of FIRST. - princessnatalie [more]
Unread 17-02-2010, 14:17
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
pic: Integrated, easy to use chain tensioners
Unread 17-02-2010, 14:20
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: pic: Integrated, easy to use chain tensioners
I like the use of turnbuckles.
My team has had good luck for years just dimensioning the spacing properly and not having any adjustment. =shrug=
Unread 17-02-2010, 15:35
J_Beth J_Beth is offline
AKA: Justin Beth
FRC #0935 (RaileRobotics)
J_Beth will become famous soon enoughJ_Beth will become famous soon enough
I like the idea. the only problem that i could see is it bending because it is only attached in two corners. But if that is not a problem then i like it.
"I Wanna Be A Robot Maker!!!!"
Unread 17-02-2010, 15:38
BEEKMAN BEEKMAN is offline
AKA: Brendan McLeod
FRC #0190 (Gompei and the Herd)
BEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to behold
i like it! very original
Unread 17-02-2010, 16:02
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
That is a sweet looking idea.
In the picture, won't the motor hit the metal plate below it as you tighten the turnbuckle?
Unread 17-02-2010, 17:33
Lightbulb Re: pic: Integrated, easy to use chain tensioners
We aren't worried too much about anything bending - it's all strong enough to handle the stress that will be placed on it.
As pointed out... The bottom pan does restrict the rotation a bit... That's one of the challenges of going over the bump! We think we still have enough adjustment for our needs - if we need more, somethig is seriously wrong.
Unread 17-02-2010, 21:36
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
We tried using a turnbuckle for this purpose on our arm motor in 2008, and every time we got any bit of tension on it, the loop side of the turnbuckle bent open. I hope it works for you, but do monitor the stresses on the turnbuckle hooks.
Unread 17-02-2010, 22:02
DonRotolo's Avatar
Back to humble
FRC #0832
Now, I'm an electrical guy, but I'd be worried about the torque that the upper nut and screw will experience, which comes from the fact that the chain is pulling on that gearbox a few inches away from the gearbox's center. Seems to me you're going to bend that bolt right quick. It won't come out easily when it does.
Unread 18-02-2010, 13:22
daltore - The gear box has been fully tensioned for over a week now, and we haven't seen any deformation of parts. How was yours used - in tension or in compression? It's hard to explain, but the turnbuckle here pushes out against the two bolts, so most of the force is directed along its axis, instead of on the loops. If we ran it the other way (from a different corner, for example) where it was pulling on the gear box to create tension, i would expect we might see the loops open up.
Don - It's hard to see in the picture, but that upper corner is supported on both sides by some pretty thick aluminum, and those plates are part of a bracket that attaches to the frame very securely. We aren't worried at all about the bolt sheering, and if it does happen to bend a little... we have saws and drills that can get it out if we have to use the box in another robot
Unread 21-02-2010, 22:37
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
I would recommend using left and right threaded rod ends. They're able to sustain more misalignment and loading than the generic hardware store turnbuckles. One can order all of the parts from McMaster without much fuss.
pic: Modified/Integrated Transmission Thermal Extra Discussion 15 04-12-2009 12:47
pic: Sliding Wheel Chain Tensioners Ice Berg Extra Discussion 18 22-04-2009 00:45
pic: 2158 chain tensioners Richard McClellan Extra Discussion 9 14-02-2008 08:58
pic: Another Use for the Energy Chain! GRST Extra Discussion 1 19-01-2008 20:40
Chain Tensioners sanddrag Technical Discussion 24 25-02-2006 19:39
