Go to Post ...when you hear a kid say "oink oink" and you say in your head "BOOM!" - delsaner [more]
Unread 17-02-2010, 13:28
neg0riz0r neg0riz0r is offline
neg0riz0r is an unknown quantity at this point
Debugging without Driver Station?
Hello,
I am trying to help the local robotics team a little bit with their programming.
Right now we (try to) program on one quite fast computer, build the program, deploy it to the cRIO and then switch to the driver stations driver mode to test it.
I have to short questions to that:
1. Do we really have to build the programm everytime we make slight chances? This takes pretty long
2. Is there a way to run the code to debug it without using the lame driver station?
Or do I really have to program on the driver station to be able to access the debugging?
Thank you very much
Neg0riz0r
Unread 17-02-2010, 14:16
Omar's Avatar
Omar Omar is offline
Omar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of light
Re: Debugging without Driver Station?
You do not have to use the small Classmate.
You can use a better faster pc/laptop to debug your code
But you do need to have the Driver Station exe running on the faster computer to be able to enable the robot. Plus the stop button and the joysticks plugged in.
To run the code and watch it run from the faster computer just hit the Run Arrow and it will down load and run in one action.
Omar
Unread 17-02-2010, 14:23
Thanks a lot, bro.
Driver Station? qpang FRC Control System 2 27-01-2010 16:59
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 10-01-2010 15:04
Driver station... the man Control System 16 06-01-2010 21:06
driver station corps FRC Control System 5 06-08-2009 20:44
Driver Station dnrobotics11 Control System 2 18-02-2009 21:35
