Go to Post During the day on Thursday, I had to change costumes a few times, being "Andy the inspector", to "Andy the green power ranger drive coach", to "Andy the President of AndyMark, meeting with companies". I am sure some people in the guys' bathroom were wondering what I was up to. - Andy Baker [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 17-02-2010, 15:52
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Re: Speed direction in CAN?
Hi Mike,
OK, so just so I'm clear here. The Encoder Line count isn't the number of lines from the encoder, but rather the number of pulses per revolution? And, that would mean that the number of Potentiometer turns would be 1 if we're using an encoder? You don't happen to know the units of the voltage ramp setting do you? Volts/revolution? Volts/Second? Volts/light year? I really wish the API guide was a bit more, er, fleshed out.
TIA,
Mike
How can you figure out robot speed?!?! gnirts Programming 7 01-04-2006 13:05
Edit- Can we connect more than one speed controller fan per breaker? DemonYawgmoth Rules/Strategy 7 03-02-2006 21:37
Can we use old Relays and Speed Controllers? thoughtful Control System 14 17-01-2005 14:55
Can we use old Relays and Speed Controllers? thoughtful Electrical 14 17-01-2005 14:55
Need direction...... archiver 2001 0 24-06-2002 02:17
