#14
Re: cRIO not turning on!!!
You may also want to check to make sure the power connector to the cRIO is connected properly. I've seen several instances where a cRIO does not turn on, it's because of a lose wire.
| cRIO Not Working?!? | JohnFogarty | Electrical | 6 | 17-01-2010 15:53 |
| cRIO Not Working?!? | JohnFogarty | Control System | 2 | 17-01-2010 08:33 |
| cRio not working...? | Jack Gillespie | Programming | 22 | 13-02-2009 13:07 |
| CRio Not Responding | Shadow_Cat | NI LabVIEW | 7 | 13-02-2009 08:12 |
| 1 joystick controls not turning properly | andrew_4_life | Programming | 4 | 28-03-2008 01:22 |
