Go to Post Lucky breaks and trying to minimize failures or moments of retardedness are what these games are all about, like any sport. - Bill Gold [more]
Unread 17-02-2010, 16:40
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
Re: Default function pinouts on Psoc I/O board
Originally Posted by PhilBot View Post
I feel like a dummy asking this, but I can't find out what the default pin/function mappings are for the Cypress board.
I have the "actual" pin/function designations, but where are the "compatibility" functions identified...
I have not seen this documented anywhere. The closest thing is the default settings on the I/O tab of the driver station.
eg: there are 8 analog inputs on the board, but only 4 in the default "DS Compatibility" interface.... so.. I'm to assume that we only use analog channels 1,2,3 & 4 on the Cypress board??
First 4, yes.
But what about the digital channels.
DS Compatibility interface has 8 digital inputs and 8 digital outputs.
It "appears" that cypress digital channels 1-8 corrospond to the inputs, and 9-16 corrospond to the outputs, but I'm just guessing....
This is accurate with what we have observed and used in the past. The first 8 are inputs (I believe pulled up or floating, I don't recall which - last year's DS was floating, so that would be closest match, but I seem to recall observing these as pulled up).
The second 8 are outputs.
Note that if you were to move to the enhanced I/O configuration, you can make a definitive selection of each pin assignment, control direction of pull (or floating) on inputs, eliminating any doubt and guesswork.
Windows "Malfunctioning USB Device" error with Psoc IO Board WarrenPW FRC Control System 2 11-02-2010 18:53
Wiring Switches to the PSoC board Raj1977 Electrical 13 07-02-2010 23:24
Camera Pinouts? kiettyyyy Programming 7 09-04-2006 10:12
Pinouts CronosPrime1 Programming 1 04-02-2006 22:54
RNet Pinouts archiver 1999 1 23-06-2002 23:18
