Go to Post I know you've finished the first 75% of the robot, but do you have enough time left to finish the other 75%? - Rick TYler [more]
Unread 17-02-2010, 16:44
Brian_servant Brian_servant is offline
FRC #3208
Brian_servant is an unknown quantity at this point
Exclamation Servo Problem
My team (3208) has been having alot of problems with the servos not responding to the program at all. We have plugged them into the PWM and attempted to use them but they didn't work. When we try the same program with the motors it works perfectly. We've tried using different servos but they didn't work either. We also tried using them in different slots but this didn't work either.
Thanks,
Gage LaCharite
Problem with servo control Jake The Man NI LabVIEW 2 09-02-2010 23:23
[FTC]: LABView Servo Problem Geek_Girl FIRST Tech Challenge 9 16-02-2009 19:29
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
vex servo problem trigger VEX 3 05-10-2008 23:44
Problem controlling a servo Entropia Programming 2 18-06-2005 18:36
