Go to Post FIRST isn't about money or robots... it is about people. Take care of that and the rest will follow. - dtengineering [more]
Unread 17-02-2010, 16:44
Brian_servant Brian_servant is offline
FRC #3208
Brian_servant is an unknown quantity at this point
Exclamation Servo Problem
My team (3208) has been having alot of problems with the servos not responding to the program at all. We have plugged them into the PWM and attempted to use them but they didn't work. When we try the same program with the motors it works perfectly. We've tried using different servos but they didn't work either. We also tried using them in different slots but this didn't work either.
Thanks,
Gage LaCharite
Unread 17-02-2010, 16:55
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Re: Servo Problem
Hi,
Are you placing a jumper on the headers adjacent to the PWM port the servo is connected to? This is required to enable 6V output to power the servo.
Once you place a jumper on one of these ports, it is not recommended to connect it to a speed controller.
For more information see section 3.4 of the control system manual.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Problem with servo control Jake The Man NI LabVIEW 2 09-02-2010 23:23
[FTC]: LABView Servo Problem Geek_Girl FIRST Tech Challenge 9 16-02-2009 19:29
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
vex servo problem trigger VEX 3 05-10-2008 23:44
Problem controlling a servo Entropia Programming 2 18-06-2005 18:36
