Go to Post Brandon, can you make some sort of mind-reading device that i can just think "portal" and i'll go back? - Tom Schindler [more]
Unread 17-02-2010, 17:02
Itamar's Avatar
Itamar Itamar is offline
FRC #1943 (NeatTeam) & FRC #4590 (GreenBlitz)
Itamar is an unknown quantity at this point
Getting Info from the robot on the dashboard
Hello,
We want to get information on the dashboard project from the robot.
I know there is some information I can already get on it like the Camera image, Camera target, gyro Angle and Joystick X.
I want to know how to have any information i want to display on the dashboard, both electronic componnets information and even variables which we create.
If that is possible I would realy like to know how.
Thank you.
Unread 18-02-2010, 06:22
Re: Getting Info from the robot on the dashboard
http://www.lvmastery.com/TipJar2009-02-10
or
http://decibel.ni.com/content/docs/DOC-8862
may help.
Greg McKaskle
Unread 18-02-2010, 11:04
Itamar's Avatar
Thank you very much, it helped and it works now.
However the speed it takes the dashboard to update my indicator is very slow, and I am sure it can be improved.
The X value of the joystick which the dashboard gets from the default code is being updated almost instantly.
If someone knows how to raise the updating speed I would realy like to know.
I have attached a dashboard project and a robot project which contain this piece of code, so if you can check what I did wrong it would be great.
Unread 18-02-2010, 12:56
By default, the robot code for LV only updates the dashboard twice a second. If you want to speed it up, you can make modifications to the team VI called Build Dashboard Data. The easy edit is to the right hand side of the loop where it updates on call 0 and 25. Add a few other numbers there to achieve the frames where you wish to transmit.
Greg McKaskle
Getting Encoder Values in the Dashboard Kyledoo C/C++ 8 09-02-2010 12:07
Getting the Image from the Camera Using Windriver (C++) computerish C/C++ 0 17-01-2009 16:03
Not getting robot info on Dashboard (C++) ellisk C/C++ 7 14-01-2009 14:58
Getting data from the robot mfwit LabView and Data Acquisition 1 19-02-2006 20:07
From the Ice Age to Robot City. The Few, The Proud, The Machines (new movie) Elgin Clock Televised Robotics 21 14-03-2005 15:14
